Tecno N8 unlock network Hi there i have Tecno N8 with network lock i try to unlock but says device not locked. i realize the bootloader was locked so i unlock it but still failed to unlock. can please team help on this.... below are the logs:.... Operation : SP Unlock [ v1.58 ] Mode : Direct Unlock 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 4500017045433848B50C01380F5144E1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 8EC8H [eMMC] : FLASH_CID : 700100454838434538010CB5E144C30F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001C8000000 [eMMC] : FLASH_UCP : 7296 MiB [eMMC 8 GiB] DEV RID : 0xE12D6E17D1E6BC1EC23D8B75FCA2A325 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Lock Status : Not Locked! Done! Elapsed: 00:00:15 Reconnect Power/Cable! Any one plz help |
Any one who can help plz |
Tried many times with cm2 but got same error that device not locked, other tools unlocked it so dont waste ur time trying unlocking N8 with cm2 simply because the phone is not supported by infinity... Find another tool |
It is MT6580 not MT6737. Choose the correct CPU from Infinity interface. |
2-Backup NV first,FIX baseband with DEEP-FIX Ticked,after switch on phone Fully. Now switch off ,then UNLOCK AGAIN Results ?? |
Thanks all.. i flash it with unlocked firmware by sp tool and set is done. |
