09-24-2019, 11:02 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | tecno spark 3pro(KB8) frp unlock please Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! INFO : max-download-size: 0x8000000 INFO : variant: INFO : logical-block-size: 0x200 INFO : erase-block-size: 0x80000 INFO : hw-revision: ca01 INFO : battery-soc-ok: yes INFO : battery-voltage: 4163mV INFO : partition-size:flashinfo: 1000000 INFO : partition-type:flashinfo: raw data INFO : partition-sizetp: 2b00000 INFO : partition-typetp: raw data INFO : partition-size:userdata: 63c3fbe00 INFO : partition-type:userdata: ext4 INFO : partition-size:nvdata: 4180000 INFO : partition-type:nvdata: ext4 INFO : partition-size:nvcfg: 2000000 INFO : partition-type:nvcfg: ext4 INFO : partition-size:tranfs: 12c00000 INFO : partition-type:tranfs: raw data INFO : partition-size:frp: 100000 INFO : partition-type:frp: raw data INFO : partition-size:expdb: 1400000 INFO : partition-type:expdb: raw data INFO : partition-size:boot_para: 100000 INFO : partition-type:boot_para: raw data INFO : partition-size:metadata: 2000000 INFO : partition-type:metadata: raw data INFO : partition-sizeara: 80000 INFO : partition-typeara: raw data INFO : partition-sizeroinfo: 300000 INFO : partition-typeroinfo: raw data INFO : partition-size:tkv: 100000 INFO : partition-type:tkv: raw data INFO : partition-size:recovery: 2000000 INFO : partition-type:recovery: raw data INFO : partition-size:cache: c800000 INFO : partition-type:cache: ext4 INFO : partition-sizerotect2: 800000 INFO : partition-typerotect2: ext4 INFO : partition-sizerotect1: 800000 INFO : partition-typerotect1: ext4 INFO : partition-sizeersist: 3000000 INFO : partition-typeersist: ext4 INFO : partition-size:vbmeta: 800000 INFO : partition-type:vbmeta: ext4 INFO : partition-size:system: b1000000 INFO : partition-type:system: ext4 INFO : partition-size:vendor: 18000000 INFO : partition-type:vendor: raw data INFO : partition-size:tee2: 600000 INFO : partition-type:tee2: raw data INFO : partition-size:tee1: 500000 INFO : partition-type:tee1: raw data INFO : partition-size:dtbo: 800000 INFO : partition-type:dtbo: raw data INFO : partition-size:logo: 800000 INFO : partition-type:logo: raw data INFO : partition-size:boot: 2000000 INFO : partition-type:boot: raw data INFO : partition-size:lk2: 100000 INFO : partition-type:lk2: raw data INFO : partition-size:lk: 100000 INFO : partition-type:lk: raw data INFO : partition-size:nvram: 4000000 INFO : partition-type:nvram: raw data INFO : partition-size:gz2: 1000000 INFO : partition-type:gz2: raw data INFO : partition-size:gz1: 1000000 INFO : partition-type:gz1: raw data INFO : partition-size:sspm_2: 100000 INFO : partition-type:sspm_2: raw data INFO : partition-size:sspm_1: 100000 INFO : partition-type:sspm_1: raw data INFO : partition-size:scp2: 100000 INFO : partition-type:scp2: raw data INFO : partition-size:scp1: 100000 INFO : partition-type:scp1: raw data INFO : partition-size:spmfw: 100000 INFO : partition-type:spmfw: raw data INFO : partition-size:md1img: 6400000 INFO : partition-type:md1img: raw data INFO : partition-size:sec1: 200000 INFO : partition-type:sec1: raw data INFO : partition-size:seccfg: 800000 INFO : partition-type:seccfg: raw data INFO : partition-sizereloader: 40000 INFO : partition-typereloader: raw data INFO : serialno: 0408211972108803 INFO : off-mode-charge: 1 INFO : warranty: yes INFO : unlocked: no INFO : secure: yes INFO : kernel: lk INFO : product: kb8_h624 INFO : slot-count: 0 INFO : version-baseband: MOLY.LR12A.R3.MP.V39.3.P21 INFO : version-bootloader: kb8_h624-904e8ac--20190717122554 INFO : version-preloader: INFO : version: 0.5 INFO : Done!! OEM : FAILunknown command Done! Elapsed: 00:00:06 |
09-24-2019, 11:11 | #2 (permalink) |
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | info about the above tecno spark 3 i need DA File please 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 65 ] Sync... Inital Boot Ok! BB_CPU_PID : 0717 BB_CPU_NME : [MediaTek] MTxxx BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0200 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0003 PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! |
09-24-2019, 11:22 | #3 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | Hello your phone cpu MT6761 Select MODE : TECNO : SECURE_v2 in CM2MT2 and connect the phone use volume down for boot key and post result Good Luck! |
The Following User Says Thank You to gracy_elec For This Useful Post: |
09-24-2019, 11:35 | #4 (permalink) | |
No Life Poster Join Date: Jul 2010 Location: cameroon
Member: 1356561 Status: Offline Thanks Meter: 433 | Quote:
use da tecno cf7 | |
The Following User Says Thank You to idrissou mohama For This Useful Post: |
