11-05-2017, 01:55 | #1 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Tecno W3 can't read successfully Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 700100454838434538010B742724A3B9 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! |
11-05-2017, 06:51 | #2 (permalink) |
Freak Poster Join Date: Feb 2013 Location: algeria
Member: 1882912 Status: Offline Sonork: 100.1677703 Thanks Meter: 263 | BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 700100454838434538010B742724A3B9 try connect phone without presing any kays |
The Following User Says Thank You to MDxavi For This Useful Post: |
11-05-2017, 08:08 | #3 (permalink) | |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
11-05-2017, 08:20 | #4 (permalink) |
Member: 1882912 Status: Offline Sonork: 100.1677703 Thanks Meter: 263 | what condition your phone right now? from your log phone dead$ PreLoader : NOT Active [ Erased ] |
11-05-2017, 09:08 | #6 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Select firmware and try again, seems this id is not in DB. Rare case, it could be due to Dram problem also. Br. Infinity Box Team. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
11-05-2017, 17:59 | #12 (permalink) |
Freak Poster Join Date: Apr 2012 Location: World Age: 37
Member: 1753151 Status: Offline Sonork: 100.1658597 Thanks Meter: 332 | Remember that 80% of tecno W3 have corrupted EMMC. Change EMMC or PCB |
The Following 2 Users Say Thank You to Ouzigzag For This Useful Post: |
