Old 02-03-2015, 11:50   #1 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
Mircomaxx a45 MT6572 NAND cpu done with cm2
Operation : Check / Read Info [ v1.10 ]
Wait for phone...
Phone found! [ 262 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 009800BC009000660076001500010000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x007F , [TOSHIBA] TYBC0A111557KC
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001
[NAND] : FLASH_LEN : 0x20000000
INT RAM : 0x00020000
EXT RAM : 0x10000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
NAND : Detecting structure now... Please, wait.
NAND : Structure detect done
Initial info read Ok!
Done!
Elapsed: 00:00:30
Reconnect Power/Cable!
Operation : Format FileSystem [ v1.10 ]
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Format : UserData Only (Factory Reset)
Format UDA block
Format block Ok!
Done!
Elapsed: 00:00:18
Old 02-04-2015, 15:49   #2 (permalink)
Member: 459784
Sonork: +91-9179403087
Thanks Meter: 1,543
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:30
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Format UDA block
Format block Ok!
Done!
Elapsed: 00:00:18
Bro! Use
Code
Option For Better Look
jpg images
The Following User Says Thank You to pradeep_kus For This Useful Post:
Page generated in 0.15049 seconds with 8 queries
