06-10-2016, 15:29 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india Age: 37
Member: 1146038 Status: Offline Thanks Meter: 196 | need help .... about rda cpu problem .... userlock in tab format fs .. i think this is driver problem all ready one more phone dead by me spice hang in logo so try to reflash but after erase not start flash and service station flash and now working at time my tab user lock so need format but cant work... please help ... Code: Card found: S/N : , v0130 Chinese Miracle II [RDA module] v 1.05 Operation : Check Device / Info ======= Settings Settings : Read AllInfo is Off Settings : Full Boot disabled by default Waiting phone ... Connect battery, press and hold 'VolUP' + 'PowerOn' buttons Connect USB cable and keep hold buttons, until phone will be detected Reconnect Power/Cable! Operation : Format File System Settings : SmartFormat is On Waiting phone ... Connect battery, press and hold 'VolUP' + 'PowerOn' buttons Connect USB cable and keep hold buttons, until phone will be detected Device found! Handshake Ok! Processing UBOT init ... Processing FL init ... Handshake with FL failed :( Factory Defaults : Will reset UserData and Settings! Format USERDATA partition ... Format USER Failed! Reboot Phone Elapsed: 00:00:59 Reconnect Power/Cable! Code: Settings : Read AllInfo is Off Settings : Full Boot disabled by default Waiting phone ... Connect battery, press and hold 'VolUP' + 'PowerOn' buttons Connect USB cable and keep hold buttons, until phone will be detected Device found! Handshake Ok! Processing UBOT init ... Processing FL init ... Handshake with FL failed :( Reading Info ... RDA 881x series CPU Detected 4 Sim Slot(s) Current Phone IMEI's : IMEI1 : 00000004AEAE330 IMEI2 : 0FFFF0000000000 IMEI3 : 00045B011003000 IMEI4 : 04E71E330E0E032 Connectivity Data : BT_MAC : 000000000000 WiFi_MAC : 000068604200 Elapsed: 00:00:26 Reconnect Power/Cable! |
