03-23-2009, 08:36 | #1 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 701779 Status: Offline Sonork: 100.1622334 Thanks Meter: 121 | test report for I phone 16Gb failed INFINITY module v2.79 Device: Autodetect 6228-6230 NAND Checking data, wait... Action: write NAND flash read mode: 01 write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs source data: page only identification#1 protocol ver: 04 ver. sw 1: APL216_PCB01_GPRS_MT6230_S02.APL216_V1_2_20080918. BIN ver. sw 2: APL216_V1.2_20080918, 9C534816 ffs offset/size: 02000000/06000000 id-page1 Ok end mark #2 found nfi area detection finished: Ok Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6230:8A02:8A02]... CPU: MT6230 high speed boot Off chip: 0031:0000:0101 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.020C loader: 3.748.0 NAND id: ECF10095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100000095 [08400000] NOR chip is not installed Initialize Done Set baud ... slowest Set baud Done Identification ... error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: reading bootloader structure area (00080000 bytes)... error: unexpected answer: warning: nfi read command is not accepted error: bootloader structure area read failed, read again... error: unexpected answer: warning: nfi read command is not accepted error: can't read area required for bootloader structure detection: 00000000 instead of 00080000 error: unexpected answer: Identification Done Write ... error: unexpected answer: error: write bootloader command is not accepted error: can't write nand bootloader Write Fail Finished, time used: 160 sec Remove/Install battery now ! |
03-23-2009, 09:35 | #2 (permalink) |
Member: 701779 Status: Offline Sonork: 100.1622334 Thanks Meter: 121 | another test result.. ==== log: [3/23/2009 4:36:50 PM] ==== COM6 [VCP1] selected module v2.79 Device: Autodetect 6228-6230 NAND Checking data, wait... Action: write NAND flash read mode: 01 write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs source data: page only identification#1 protocol ver: 04 ver. sw 1: APL216_PCB01_GPRS_MT6230_S02.APL216_V1_2_20080918. BIN ver. sw 2: APL216_V1.2_20080918, 9C534816 ffs offset/size: 02000000/06000000 id-page1 Ok end mark #4 found nfi area detection finished: Ok Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6230:8A02:8A02]... CPU: MT6230 high speed boot On chip: 0031:0000:0101 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.020C loader: 3.748.0 NAND id: ECF10095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100000095 [08400000] NOR chip is not installed Initialize Done Set baud ... slowest Set baud Done Identification ... reading bootloader structure area (00080000 bytes)... detecting bootloader structure... warning: probably flash chip completely erased, no bootloader found nfi area detection finished: failed detecting bootloader structure by source file... source data: page only identification#1 protocol ver: 04 ver. sw 1: APL216_PCB01_GPRS_MT6230_S02.APL216_V1_2_20080918. BIN ver. sw 2: APL216_V1.2_20080918, 9C534816 ffs offset/size: 02000000/06000000 id-page1 Ok nfi area detection finished: Ok identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.277ADFDB.[APL216_PCB01_GPRS_MT6230_S02.APL216_V1_2_20080918. BIN_E9B7AC63].rpl identification#1 detection finished security area (code #1) calculation... Identification Done Write ... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_277ADFDB_APL216_PCB01_GPRS_MT6230_S02.AP L216_V1_2_20080918.BIN_E9B7AC63_20090323-163807.B4X.bin 00006000 bytes sent write core area 1 of 3... 00417400 bytes sent write core area 2 of 3... 010BEC00 bytes sent write core area 3 of 3... 00635400 bytes sent Write Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_277ADFDB_APL216_PCB01_GPRS_MT6230_S02.AP L216_V1_2_20080918.BIN_E9B7AC63_20090323-172235.B4X.bin Finished, time used: 2742 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [3/23/2009 5:23:51 PM] ==== COM6 [VCP1] selected module v2.79 Device: Autodetect 6228-6230 NAND Checking data, wait... Action: NAND reset read mode: 01 Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6230:8A02:8A02]... CPU: MT6230 high speed boot On chip: 0031:0000:0101 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.020C loader: 3.748.0 NAND id: ECF10095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100000095 [08400000] NOR chip is not installed Initialize Done Set baud ... slowest Set baud Done Identification ... reading bootloader structure area (00080000 bytes)... detecting bootloader structure... source data: page only identification#1 protocol ver: 04 ver. sw 1: APL216_PCB01_GPRS_MT6230_S02.APL216_V1_2_20080918. BIN ver. sw 2: APL216_V1.2_20080918, 9C534816 ffs offset/size: 02000000/06000000 id-page1 Ok nfi area detection finished: Ok identification#1 structure: 2nd [enhanced] generation security area (code #1) is damaged, recalculation required identification#1 detection finished Identification Done Write ... formatting... ..error: code: 1C00006900 ...error: code: 4000006900 .................................................. ...............................error: code: 2200006900 ....error: code: 6400006900 ..........error: code: A502000000 error: code: 0600000000 Write Fail Finished, time used: 83 sec Remove/Install battery now ! |
03-23-2009, 10:38 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | 1. What is the reason to start new thread each time instead of make an answers in old threads ? 2. You must check your phone hardware or your cable due to now I am sure that software works without problems. Why so ? Easy answer: I see good test report from other user who has EXACTLY the same phone (just compare firmware version name): http://www.mcrf.ru/forum/showthread.php?t=19807 p.s. Information for all users: many users make answers to only one question from the questions that was asked by supporter. It is really terrible situation for supporters (we can not understand reason of this kind of ignorance) so from today we will close any thread if users did not make an answers to all questions that was asked by supporters. Thank you for your understanding and cooperation ! |
Test report for 5.91 1208 | zipzap_kill | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 10-23-2009 07:07 |
Test Report for new UPDATE 1.06 | alfox | Cyclonebox | 2 | 08-14-2009 19:14 |
About I phone 16GB sir infinity... | lorenzo roberto | Infinity-Box | 2 | 03-20-2009 08:40 |
Worked and tested pinouts for Chinese phones are here | GSMtricks | Chinese Cocktail | 32 | 10-22-2008 15:27 |
Auto PinFinder Adapter for Chinese phones launched by Infinity Box Team | InfinityHelp | Main Sales Section | 0 | 04-06-2008 11:26 |
