02-19-2015, 12:23 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | Testing read and write Factory file With infinity box READ flash file connect phone on preloader not need root, usb debugging or etc reed file size = 678 Mb only factory file File read time = 4.17 min factory file write by box = not supported yet write by sp flasher = 4-5 min only result after flashing perfect phone working after flash before flashing phone was logo hang conclusion perfect read write + supper fast time happy with it only missing box not supported direct scatter file write BY Miracle box connect phone on preloader reed file size = 2. 02 Gb read factory file time = 20-25 min factory file write by box = 15 -18 min write by sp flasher = mostly time it can not write Code: Waiting for USB Port... Set PreLoader USB VCOM Port (COM7) Please Hold "ON" to connect with the phone...USB Connected to Phone. CPU: MT6572 SW:0000 Ver: CA01 Downloading Boot8 ... EMMC Size: 0xE7000000 INT/EXT RAM Size: 0x0+0x0 Writing(Nand/eMMC)... Writing MBR Writing EBR1 Writing NVRAM Writing PROTECT_F Writing PROTECT_S Writing UBOOT Writing BOOTIMG Writing RECOVERY Writing SEC_RO Writing MISC Writing LOGO Writing EXPDB Writing ANDROID Writing CACHE Writing USRDATA Writing FAT Checking Sum... Write Done. Total time: 17 mins 31 s result after write file perfect phone working after flash conclusion software read write ok but take too much time for read write solw working + file size big extra user date read,write by volcano box only box which need phone fully power on + usb debugging + emmc card on phone + phone need root before reading factory file reed file size = 1.64 gb factory file File read time = 20-25 min factory file write by box = supported write by sp flasher = 6-7 min only result after flashing flash scatter file by box = phone blue display only flash by sp flasher = phone on logo hange not full power on conclusion wast of time no perfect read no perfect write what is your opinion in my list infinity box is best and perfect if some one not belive then test your self or i have all files i can upload it |
The Following 13 Users Say Thank You to sweet4hamza For This Useful Post: |
02-19-2015, 12:58 | #2 (permalink) |
No Life Poster Join Date: Jun 2011 Location: pakistan
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | yes bro. i agree to you Infinity Best Box is Best of all i dont have this box but i will purchase it soon thanks for your opinion Br GSM City |
The Following User Says Thank You to Muhammadsaqib11 For This Useful Post: |
02-19-2015, 13:03 | #3 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Infinity CM2 only reads needed files from phone for factory files, so it takes lesser time and less size, unlike all other tools. And reading speed is also very fast. Scat writing will be enabled soon in coming updates. Enjoy using Infinity CM2. Br. |
The Following 3 Users Say Thank You to PASSIONATE_BOYS For This Useful Post: |
02-19-2015, 13:20 | #4 (permalink) |
Freak Poster Join Date: Feb 2013 Location: Where YOu Cant Go Age: 25
Member: 1877938 Status: Offline Sonork: 100.1659358 Thanks Meter: 72 | I dont agree with u bcoz volcano is best box for all android chinese phone.it support more chipset than other box.CHeck The latest VErsion OF VolCano box |
02-19-2015, 13:35 | #5 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: Gampaha, Srilanka
Member: 527534 Status: Offline Sonork: 100.1606510 Thanks Meter: 193 | Quote:
And @sweet4hamza Nice to see you here as like this....... Because your real talent and honest ideas comes with this free way. Its a great help for us to build our knowledge. | |
02-19-2015, 13:42 | #6 (permalink) | |
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | Quote:
i am already on latest version please check screenshot if you not agree make test your self , then tell us current volcano have just updates but its not work as other product also same just check his section | |
The Following User Says Thank You to sweet4hamza For This Useful Post: |
02-19-2015, 14:59 | #8 (permalink) |
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | Qmobile X2 read flash read ptran lock and format done with no risk Operation : Read Flash [ v1.12 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001600080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info MTKxCPU : MT6571 MTKxPRJ : s3510ap Saved to : F:\Andriod files\x2\MT6571__s3510ap.ispff Done! Elapsed: 00:04:30 Reconnect Power/Cable! Operation : Read PatternLock [ v1.12 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001600080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... Reading data ... Please, wait Checking ... Get PatternLock ... PatternLock Sequnce : 1548 Done! Elapsed: 00:01:31 Reconnect Power/Cable! Operation : Format FileSystem [ v1.12 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001600080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to sweet4hamza For This Useful Post: |
02-19-2015, 15:13 | #10 (permalink) |
No Life Poster Join Date: Feb 2005 Location: tampin malaysia Age: 61
Member: 117956 Status: Offline Thanks Meter: 115 | Thanks for a read write tested result , how about format for phone hang at logo ? I got infinity old box , your tested result much appreciate for me to activate CM2 ! Thank you ! |
02-19-2015, 15:17 | #11 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
You can check success reports here- MTK- http://forum.gsmhosting.com/vbb/f296...iatek-1862422/ SPD- http://forum.gsmhosting.com/vbb/f296...dtrum-1862960/ Rda/Coolsand- http://forum.gsmhosting.com/vbb/f296...eased-1878249/ And many more, just look on Infinity section. Latest format result on Karboon Titanium S9- http://forum.gsmhosting.com/vbb/f296...l#post10875747 Br. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
02-19-2015, 15:31 | #12 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Republic of Mindanao
Member: 990900 Status: Offline Thanks Meter: 540 | yes bro. i agree to you Infinity Best Box is Best of all china tool scatter file dump, Advance CM2MTK 1,you can dump scatter file,no problem touch screen broken everything under control CM2MTK 2,Hung logo OMG if cannot believe but CM2MTk can dump scatter file here in the evidence....http://forum.gsmhosting.com/vbb/f296...flash-1917795/ 3,No need to ROOT the phone before dump scatter 4,No need to put mmc card to Dump scatter file and Power On normal Mode 5,No need to DEBUGG..........bye bye VM tools here is my test report http://forum.gsmhosting.com/vbb/f296...eport-1915497/ |
02-19-2015, 15:52 | #13 (permalink) | |
check my post 10 its latest 6571 chip inside phone and infinity box done format it and phone working perfect infinty box is more faster, safe work then current | |
The Following 2 Users Say Thank You to sweet4hamza For This Useful Post: |
02-19-2015, 16:05 | #14 (permalink) |
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | g mail remove by format without any risk without any backup , without any root without bla bla Operation : Format FileSystem [ v1.12 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 199 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0068 , [HYNIX] H8BCS0CG0MBR [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! Elapsed: 00:00:06 Reconnect Power/Cable! |
The Following 5 Users Say Thank You to sweet4hamza For This Useful Post: |
