thx infinity team, unlock now j110 100% hello thx infinity team now i unlock j110i succes the unoutorized phones i give yesterday customer retourn but have many to unlock. her some succes unlock j110 log COM12 [VCP0] selected Device: SE-J110i "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb version sw: 039C-000 version sw: KIM-5- Check flash Done Check parameters... reading SE-J110i_eeprom_calibration-1... file saved: backup_SE-J110i_eeprom_calibration-1_20071011-002037.6AE.bin Check parameters Done Check data... Check data Done Writing... flash: 89886200010001:89886200000000 Write: eeprom Writing Done Finished, time used: 36 sec Remove/Install battery now ! first 100% unlocked COM12 [VCP0] selected Device: SE-J110i "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb version sw: 039C-000 version sw: KIM-5- Check flash Done Check parameters... reading SE-J110i_eeprom_calibration-1... file saved: backup_SE-J110i_eeprom_calibration-1_20071011-002633.6AE.bin Check parameters Done Check data... Check data Done Writing... flash: 89886200010001:89886200000000 Write: eeprom Writing Done Finished, time used: 23 sec Remove/Install battery now ! second 100% unlocked COM12 [VCP0] selected Device: SE-J110i "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb version sw: 039C-000 version sw: KIM-5- Check flash Done Check parameters... reading SE-J110i_eeprom_calibration-1... file saved: backup_SE-J110i_eeprom_calibration-1_20071011-002839.6AE.bin Check parameters Done Check data... Check data Done Writing... flash: 89886200010001:89886200000000 Write: eeprom Writing Done Finished, time used: 17 sec Remove/Install battery now ! third 100% unlocked now work fine ebu mohammed-emin |
thanks for the test result |
Infinity-Box :Dthanks for the test ---Infinity-Box |
and her log from j120i COM12 [VCP0] selected Device: SE-J120i "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb version sw: 032H-000 version sw: MLD-5- Check flash Done Check parameters... reading SE-J120i_eeprom_calibration-1... file saved: backup_SE-J120i_eeprom_calibration-1_20071011-024118.6AE.bin Check parameters Done Check data... Check data Done Writing... flash: 89886200010001:89886200000000 Write: eeprom Writing Done Finished, time used: 18 sec Remove/Install battery now ! 100% unlocked ebu mohammed-emin |
yes its really Good that you done but i tried many mobiles some are unlocked and some not !! Br Faisal_Computer |
great work thanks for the info..................... |
Whath Version Hmodule Ulock J110 J120? Sorry My English |
@Montano2 update your box firmware ang use Hmodule_1.03 http://www.infinity-box.com/download...odule_1.03.rar |
thanks. good work infinity team |
infinity team thanks the bug is fixed j110i |
yes working. thanks infinity my j110i unlocked........ thanks a lot |
it is 100% working on all J110, j120 |
THX, respect, can i ask for language file for J110i with eng_shqip_bulgarian(bulgaria)_elanika(greece)_roma na(romania).. thank you very much |
download new h modul and unlock 100 % i unlock yesterday about 11x j110i and 1x j120i br. ebu mohammed-emin |
