12-12-2017, 09:15 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Chittagong Age: 35
Member: 1188409 Status: Offline Sonork: 100.1616589 Thanks Meter: 270 | TIT-AL00 Need Cm2 DA File hang on logo have read flash file bye infrono i dont have infrono so i need to flash by cm2 need DA dile any body help me pls |
12-12-2017, 09:30 | #2 (permalink) | |
No Life Poster Join Date: Mar 2016 Location: Ukraine
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Quote:
The Following 2 Users Say Thank You to localizator For This Useful Post: |
12-12-2017, 11:11 | #5 (permalink) |
Member: 2550141 Status: Offline Thanks Meter: 1,115 | 1)NEED TO CHANGE DA FILES IN BOOT FOLDER AND SELECT MT6737M_Android_scatter.txt FILE IN FLASH TAB 2)VERY IMPORTAINT BEFORE DO ANY OPREATION MAKE READ INFO 3)NEED TO PRESS VOL "+" &"-" TILL THE END OPREATION AND YOU WILL SUCCESS 4)POST LOG OPREATION 5)IF ANY PROBLEM I CAN HELP YOU OK GOOD LUCK Last edited by localizator; 12-12-2017 at 11:16. |
The Following 3 Users Say Thank You to localizator For This Useful Post: |
12-12-2017, 11:40 | #6 (permalink) |
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Flash this firmware https://drive.google.com/file/d/0Bx5...F4VHpJX1k/view |
12-12-2017, 11:53 | #8 (permalink) | |
Member: 1188409 Status: Offline Sonork: 100.1616589 Thanks Meter: 270 | Quote:
avble only in infrono but i dont have | |
The Following User Says Thank You to .:::SM PRINCE:::. For This Useful Post: |
12-13-2017, 09:21 | #12 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Bulgaria
Member: 877235 Status: Offline Sonork: vasilbojilov Thanks Meter: 199 | ALL THIS ONLY FOR TIT-AL00 Recover the phone, which is killed soft (vibrates and all). 1. Download the archive (https://yadi.sk/d/q_td42FxyXYxq) 2. Unpack it all. 3. Run FlashTool from the Upgrade tools & drivers folder 4. In the Download Agent tab, select da_swsec.bin from the DA_titan-ME folder (if there is an error, then DA_titan-ROW) 5. In the Scatter tab, select MT6735_Android_scatter.txt from the New folder and uncheck Preloader. 6. Select Download only and click Download. 7. Connect the phone (if the phone vibrates and does not see, then most likely it has a battery dropped out, leave it connected to USB until it is seen) |
The Following 3 Users Say Thank You to vasko_bojilov For This Useful Post: |
12-14-2017, 06:23 | #13 (permalink) | |
Thnks For Reply | |
12-14-2017, 06:55 | #14 (permalink) |
Member: 1188409 Status: Offline Sonork: 100.1616589 Thanks Meter: 270 | No Luck May I Cant Find Problem Off This Phone Its Condtion Is Hang Logo Restart Dont Take SD Update Do Go Recovery Dont Take Flash Only Boot Is MTK Preloder https://www.4shared.com/photo/YEjx6B...eenShot_9.html |
