toshiba ts608 unlock oading data, wait... [Infinity Box] v2.20 S/N: A55D:0116 Wait... Current device: DTAC-ML2 Done Current device: Toshiba-TS608 COM13 ready ==== log opened: [2/13/2012 12:39:42 PM] ==== Application: C:\Program Files\infinity-box\QModule\QModule.exe Loading data, wait... [Infinity Box] v2.20 S/N: A55D:0116 Wait... Current device: Toshiba-TS608 Done COM13 [VCP2] selected Device: Toshiba-TS608 Checking data, wait... advanced flash detection active Action: Read flash Boot... Press and HOLD Power button ! error: wrong answer, errorcode#37 Boot Fail error: Finished Remove/Install battery now ! Time used: 5 sec COM13 [VCP2] selected Device: Toshiba-TS608 Checking data, wait... advanced flash detection active Action: Read flash Boot... Press and HOLD Power button ! Connecting, wait... error: boot failed: 7D Release Power button ! error: wrong answer, errorcode#37 Boot Fail error: Finished Remove/Install battery now ! Time used: 51 sec COM13 [VCP2] selected Device: Toshiba-TS608 Checking data, wait... advanced flash detection active Action: Read Eeprom Boot... Press and HOLD Power button ! Connecting, wait... error: boot failed: 7D Release Power button ! error: wrong answer, errorcode#37 Boot Fail error: Finished Remove/Install battery now ! Time used: 15 sec COM13 [VCP2] selected Device: Toshiba-TS608 Checking data, wait... advanced flash detection active Action: Read flash Boot... Press and HOLD Power button ! Connecting, wait... error: boot failed: 7D Release Power button ! error: wrong answer, errorcode#37 Boot Fail error: Finished Remove/Install battery now ! Time used: 9 sec COM13 [VCP2] selected Device: Toshiba-TS608 Checking data, wait... advanced flash detection active Action: Read flash Boot... Press and HOLD Power button ! Connecting, wait... error: boot failed: 7D Release Power button ! error: wrong answer, errorcode#37 Boot Fail error: Finished Remove/Install battery now ! Time used: 10 sec COM13 [VCP2] selected Device: Toshiba-TS608 Checking data, wait... advanced flash detection active Action: Read flash Boot... Press and HOLD Power button ! Connecting, wait... error: boot failed: 7D Release Power button ! error: wrong answer, errorcode#37 Boot Fail error: Finished Remove/Install battery now ! Time used: 10 sec Current device: Fly-2060 COM13 [VCP2] selected Device: Fly-2060 Checking data, wait... advanced flash detection active Action: Read flash Boot... Press and HOLD Power button ! Connecting, wait... error: boot failed: 7D Release Power button ! error: wrong answer, errorcode#37 Boot Fail error: Finished Remove/Install battery now ! Time used: 9 sec Current device: Toshiba-TS608 COM13 [VCP2] selected Device: Toshiba-TS608 Checking data, wait... advanced flash detection active Action: Read flash Boot... Press and HOLD Power button ! Connecting, wait... error: boot failed: 7D Release Power button ! error: wrong answer, errorcode#37 Boot Fail error: Finished Remove/Install battery now ! Time used: 10 sec COM13 [VCP2] selected Device: Toshiba-TS608 Checking data, wait... advanced flash detection active Action: Read flash Boot... Press and HOLD Power button ! Connecting, wait... error: boot failed: 7D Release Power button ! error: wrong answer, errorcode#37 Boot Fail error: Finished Remove/Install battery now ! Time used: 10 sec COM13 ready COM13 [VCP2] selected Device: Toshiba-TS608 Checking data, wait... Action: Read flash Boot... Press and HOLD Power button ! Connecting, wait... error: boot failed: 7D Release Power button ! error: wrong answer, errorcode#37 Boot Fail error: Finished Remove/Install battery now ! Time used: 11 sec ---------------- Log opened: [2/13/2012] [1:56:02 PM] App: C:\Program Files\infinity-box\QModule\QModule.exe Loading data, wait... [Infinity Box] v2.19 S/N: A55D:0116 Wait... Current device: Panasonic-GD55 Done Current device: Toshiba-TS608 COM13 selected Device: Toshiba-TS608 Checking data, wait... Action: Read flash Boot... Press and HOLD Power button ! Connecting, wait... Err: boot failed: 7D Release Power button ! Err: wrong answer, error#01 Boot Fail Err: Finished Remove/Install battery now ! Time used: 9 sec COM13 selected Device: Toshiba-TS608 Checking data, wait... Action: Read flash Boot... Press and HOLD Power button ! Connecting, wait... Err: boot failed: 7D Release Power button ! Err: wrong answer, error#01 Boot Fail Err: Finished Remove/Install battery now ! Time used: 19 sec i have used n343i cable and i have checked to use all speeds. but not connecting . and also i have checked in 2 different versions. pls help me infinity team |
i have pressed power button long time also |
hello! make cable for infinity box. your n343i cable might be faulty or uses some bad working USB to COM IC |
working good with another port . any other mobile is not connecting in rj45. what fault with my box sir? |
hello! check this tread and compare with your connection. do you use correct pins of RJ45 port? http://forum.gsmhosting.com/vbb/f296...-cable-386780/ |
i make rx tx solder wire in the board with same pinout z3x used. then mobile is unlocked but this rj45 port is not working what should do sir??????????? :confused: |
hello! i must repeat that in infinity box RJ45 port are used pins 2,3,8 This means that cable soldered with another pinout will not work. This is what i want you to check. If your phone's GND is really connected with RJ545 pin8. and tx/rx connected with 2&3 pin |
i'll try with another mobile and reply with you |
i have one lg kg110 unlock via infinity port here is the log: COM9 [VCP0] selected module v1.39 Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... error: boot failed: 7B Release Power button now ! error: unexpected answer during boot procedure Boot Fail Finished, time used: 6 sec Remove/Install battery now ! Testing COM9 at 460800... COM9 [VCP0] selected module v1.39 Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: enhanced Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... error: boot failed: Release Power button now ! error: unexpected answer during boot procedure Boot Fail Finished, time used: 34 sec Remove/Install battery now ! Testing COM9 at 115200... at the same time i have try with same pinout port from another box. it is working good. here is the log file: COM9 [VCP0] selected module v1.39 Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: enhanced Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... error: boot failed: Release Power button now ! error: unexpected answer during boot procedure Boot Fail Finished, time used: 15 sec Remove/Install battery now ! COM3 ready Testing COM3 at 115200... ==== log: [3/26/2012 4:48:53 PM] ==== COM3 [VCP1] selected module v1.39 Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: enhanced Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... warning: wrong data size at 0x01007800, retry... warning: wrong cs at 0x01007800, retry... read error recovered current eeprom imei: 355995012841724 current otp imei: 355995012841724 file saved: C:\InfinityBox\LgA\eeprom_355995012841724_LG-KG110_20120326-164940.B1E.bin ........ version: 404-XXV20c91KG110P40FL Check flash Done Check space ... current eeprom imei: 355995012841724 Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 60 sec Remove/Install battery now ! what problem with my dongle??????????????????? |
hello! Do you have warranty on your box? maybe worth to show it to your reseller, and he will decide if it must be exchanged? |
i don't have warrenty for this dongle sir. i'm using this box last 2 years. any hardware repair needed in the box ?? |
@kavikumaran Can you double check your TS608 cable ? It will be very good if you will check your cable according to pinout given by Infinity-Box Shell. Also, you must check phone hardware (system connector) because TS608 is quite old model and there is a big chance that system connector become damaged and/or dirty. |
HELLO SIR, I KNOW VERY WELL INFINITY AND Z3X BOXES ARE SAME PINOUT. I'M USE THE SAME CABLE VIA Z3X PORT IT IS UNLOCKED. AT THE SAME CABLE I HAVE USED WITH INFINITY PORT IT IS NOT WORKING SIR.I HAVE TRIED ANOTHER ONE J120i MOBILE ALSO. PLEASE SOLVE MY PROBLEM SIR |
I do not understand what we talk now. Let's start from begin. You must give me answers one by one: 1. what phone model you talk about 2. where is GND pin at your Infinity-Box ? Is it pin-7 or pin-8 ? |
