Old 02-13-2012, 08:30   #1 (permalink)
KUMARANSUGUMAR's Avatar
Member: 726340
Sonork: 100.1624264
Thanks Meter: 85
toshiba ts608 unlock
oading data, wait...
[Infinity Box] v2.20
S/N: A55D:0116
Wait...
Current device: DTAC-ML2
Done
Current device: Toshiba-TS608
COM13 ready
==== log opened: [2/13/2012 12:39:42 PM] ====
Application: C:\Program Files\infinity-box\QModule\QModule.exe
Loading data, wait...
S/N: A55D:0116
Wait...
Done
COM13 [VCP2] selected
Device: Toshiba-TS608
Checking data, wait...
advanced flash detection active
Action: Read flash
Boot...
Press and HOLD Power button !
error: wrong answer, errorcode#37
Boot Fail
error:
Finished
Remove/Install battery now !
Time used: 5 sec
Action: Read flash
Boot...
Connecting, wait...
error: boot failed: 7D
Release Power button !
Boot Fail
error:
Finished
Time used: 51 sec
Action: Read Eeprom
Boot...
Connecting, wait...
Boot Fail
error:
Finished
Time used: 15 sec
Action: Read flash
Boot...
Connecting, wait...
Boot Fail
error:
Finished
Time used: 9 sec
Action: Read flash
Boot...
Connecting, wait...
Boot Fail
error:
Finished
Time used: 10 sec
Action: Read flash
Boot...
Connecting, wait...
Boot Fail
error:
Finished
Time used: 10 sec
Current device: Fly-2060
Device: Fly-2060
Action: Read flash
Boot...
Connecting, wait...
Boot Fail
error:
Finished
Time used: 9 sec
Action: Read flash
Boot...
Connecting, wait...
Boot Fail
error:
Finished
Time used: 10 sec
Action: Read flash
Boot...
Connecting, wait...
Boot Fail
error:
Finished
Time used: 10 sec
COM13 ready
Action: Read flash
Boot...
Connecting, wait...
Boot Fail
error:
Finished
Time used: 11 sec
Log opened: [2/13/2012] [1:56:02 PM]
App: C:\Program Files\infinity-box\QModule\QModule.exe
[Infinity Box] v2.19
S/N: A55D:0116
Wait...
Current device: Panasonic-GD55
Done
COM13 selected
Action: Read flash
Boot...
Connecting, wait...
Err: boot failed: 7D
Err: wrong answer, error#01
Boot Fail
Err:
Finished
Time used: 9 sec
COM13 selected
Action: Read flash
Boot...
Connecting, wait...
Boot Fail
Err:
Finished
Time used: 19 sec
i have used n343i cable and i have checked to use all speeds. but not connecting . and also i have checked in 2 different versions. pls help me infinity team
Old 02-13-2012, 09:00   #2 (permalink)
Member: 726340
Sonork: 100.1624264
Thanks Meter: 85
i have pressed power button long time also
Old 02-13-2012, 20:48   #3 (permalink)
Member: 148515
Thanks Meter: 16,818
hello!
make cable for infinity box. your n343i cable might be faulty or uses some bad working USB to COM IC
Old 03-16-2012, 07:26   #4 (permalink)
Member: 726340
Sonork: 100.1624264
Thanks Meter: 85
working good with another port . any other mobile is not connecting in rj45. what fault with my box sir?
Old 03-16-2012, 18:58   #5 (permalink)
Member: 148515
hello!
check this tread and compare with your connection.
do you use correct pins of RJ45 port?
http://forum.gsmhosting.com/vbb/f296...-cable-386780/
Old 03-17-2012, 08:43   #6 (permalink)
Member: 726340
Sonork: 100.1624264
Thanks Meter: 85
hello!
i make rx tx solder wire in the board with same pinout z3x used. then mobile is unlocked but this rj45 port is not working
what should do sir???????????
Old 03-17-2012, 11:48   #7 (permalink)
Member: 148515
hello!
i must repeat that in infinity box RJ45 port are used pins 2,3,8
This means that cable soldered with another pinout will not work.
This is what i want you to check. If your phone's GND is really connected with RJ545 pin8.
and tx/rx connected with 2&3 pin
Old 03-20-2012, 10:26   #8 (permalink)
Member: 726340
Sonork: 100.1624264
Thanks Meter: 85
i'll try with another mobile and reply with you
Old 03-26-2012, 12:25   #9 (permalink)
Member: 726340
Sonork: 100.1624264
Thanks Meter: 85
i have one lg kg110 unlock via infinity port
here is the log:
COM9 [VCP0] selected
module v1.39
Device: LG-KG110
Action: unlock
unlock method: standard
Boot ...
Connecting, wait...
error: boot failed: 7B
Release Power button now !
error: unexpected answer during boot procedure
Boot Fail
Finished, time used: 6 sec
Testing COM9 at 460800...
module v1.39
Device: LG-KG110
Action: unlock
unlock method: enhanced
Boot ...
Connecting, wait...
error: boot failed:
Boot Fail
Finished, time used: 34 sec
Testing COM9 at 115200...
at the same time i have try with same pinout port from another box. it is working good.
here is the log file:
module v1.39
Device: LG-KG110
Action: unlock
Boot ...
Connecting, wait...
error: boot failed:
Boot Fail
Finished, time used: 15 sec
COM3 ready
Testing COM3 at 115200...
==== log: [3/26/2012 4:48:53 PM] ====
COM3 [VCP1] selected
module v1.39
Device: LG-KG110
Action: unlock
Boot ...
Connecting, wait...
flash: 01227E22212200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Boot Done
Set baud ...
115200
Set baud Done
Check flash ...
warning: wrong data size at 0x01007800, retry...
warning: wrong cs at 0x01007800, retry...
read error recovered
current eeprom imei: 355995012841724
current otp imei: 355995012841724
file saved: C:\InfinityBox\LgA\eeprom_355995012841724_LG-KG110_20120326-164940.B1E.bin
version: 404-XXV20c91KG110P40FL
Check flash Done
Check space ...
Check space Done
Check parameters ...
Check parameters Done
Erase ...
Erase Done
Write ...
write: lock area-1
Write Done
Finished, time used: 60 sec
what problem with my dongle???????????????????
Old 03-27-2012, 17:58   #10 (permalink)
Member: 148515
hello!
Do you have warranty on your box? maybe worth to show it to your reseller, and he will decide if it must be exchanged?
Old 03-28-2012, 04:46   #11 (permalink)
Member: 726340
Sonork: 100.1624264
Thanks Meter: 85
i don't have warrenty for this dongle sir. i'm using this box last 2 years. any hardware repair needed in the box ??
Old 03-29-2012, 08:16   #12 (permalink)
Member: 1043909
Thanks Meter: 54,528
@kavikumaran
Can you double check your TS608 cable ?
It will be very good if you will check your cable according to pinout given by Infinity-Box Shell.
Also, you must check phone hardware (system connector) because TS608 is quite old model and there is a big chance that system connector become damaged and/or dirty.
Old 03-29-2012, 15:21   #13 (permalink)
Member: 726340
Sonork: 100.1624264
Thanks Meter: 85
HELLO SIR,
I KNOW VERY WELL INFINITY AND Z3X BOXES ARE SAME PINOUT. I'M USE THE SAME CABLE VIA Z3X PORT IT IS UNLOCKED. AT THE SAME CABLE I HAVE USED WITH INFINITY PORT IT IS NOT WORKING SIR.I HAVE TRIED ANOTHER ONE J120i MOBILE ALSO.
PLEASE SOLVE MY PROBLEM SIR
Old 03-29-2012, 17:03   #14 (permalink)
Member: 1043909
I do not understand what we talk now.
Let's start from begin.
You must give me answers one by one:
1. what phone model you talk about
2. where is GND pin at your Infinity-Box ? Is it pin-7 or pin-8 ?
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
FAQ about unlock n0kia man0n Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 18:06
Page generated in 0.36340 seconds with 8 queries
