<<< Trend T-101 dead after flash >>> hello infinity team, i got trend t101 in on condition , some times mobile in autorestart condition, i decide to flash the phone , i download firmware from support site & flash the phone while flashing a error message appear (see in log) . now mobile is dead , any help please. COM4 [VCP0] selected module v1.64 Device: Trend-T101 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00BF:7353 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware error: erase failed: 00400000 Write Failed Finished, time used: 23 sec Remove/Install battery now ! |
is battery was full when you trying to flash ? Please try to flash again with fully charged battery if no luck then rehot it and try again and post results Br Faisal_Computer |
read Other Set Full Flash Write 100000000000000% ok |
@khadim100 select model BSNL-G200 and flash phone again. |
i flash with BSNL-G200 firmware. but same error, please anyone upload trend t101 full flash . |
p.s. in future any thread with problem description like "the same", "still same", "same problem", "not work" etc. will be closed due to we can not help if we do not see any problem explanation |
i flash with BSNL-G200 firmware. but same error, please anyone upload trend t101 full flash . 100000% Tested |
Hello, What is "same error" exactly ? |
@InfinitySupport I encountered the same problem while flashing Trend T101 with files from support site. Same error occured "error: erase failed: 00400000" Then I made search on the forum and come to this thread. I selected model "BSNL-G200" from the list and used T101 files from the support site. All the process goes very well (no more error: erase failed: 00400000) but phone couldn't be turned ON. Then I used this file from support "Digibee-BSNL-G200CF_Jan-16-2008.B1M" and flashed the phone and the result is fully working phone. Thank you very very much for this wonderful tip. Now one question arise here why this error occur while selcted model is T101 and why flashfiles of T101 from support site are not working???? Best Regards! yawarniazi |
@Infinity After flash these flash file i have got a dead phone. Trend-T101_ULC2_Apr-18-2008.B1M Trend-T101_2007-Nov-12.B1M But i make search on google then i reach on this thread I follow instruction that write yawarniazi. I flash this file "Digibee-BSNL-G200CF_Jan-16-2008.B1M" now phone is alive and i has change IMEI of this phone. ==== log: [1/26/2010 10:02:58 AM] ==== COM23 [VCP0] selected module v1.72 Device: Digibee-BSNL-G200CF Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL Z c 0 A d 0 q Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-static_20100126-100312.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-security_20100126-100313.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-complete_20100126-100314.B1E.bin backup critical area Done Check memory ... unlocking... lock found lock type #1 found operation done Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Write Done Finished, time used: 125 sec Remove/Install battery now ! ==== log: [1/26/2010 10:05:45 AM] ==== COM23 [VCP0] selected module v1.72 Device: Digibee-BSNL-G200CF Checking data, wait... Action: "repair imei" new imei: 354401005889664 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL N W 0 A X 0 q Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-static_20100126-100559.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-security_20100126-100559.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-complete_20100126-100600.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_imei-area_20100126-100604.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_lock-area_20100126-100607.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found imei found #2 Check memory Done Write ... Erasing: imei-area Writing: imei-area Erasing: lock-area Writing: lock-area Erasing: eeprom-security Writing: eeprom-security Write Done Finished, time used: 33 sec Remove/Install battery now ! Finished |
Any body can upload fullflash file for trend t101 also eeprom plz.......... |
infinity team help me plz.............. |
Infinity team need ur help plzzzzzzzzzzzzzzzzzzzz |
