02-25-2021, 22:34 | #1 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Romania
Member: 2157664 Status: Offline Thanks Meter: 43 | Trying to connect REVVL4 I m trying to connect t-mobile revvl4. It has mediatek MT6761. It gives me this error. Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM21) MODE : BOOTROM PORT : 21 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN RAPHAEL BROM : MEID : 864225C9FDBD664D5EFDD1010F7E16F4 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Disabled BROM : SOCID : 433AC99D583481A7B24993DD0F26EF7FB6EFD3B57ABD72CB6A 74C7E7BF717060 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Selected AGENT doesn't have required configuration! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM21) MODE : BOOTROM PORT : 21 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN RAPHAEL BROM : MEID : 864225C9FDBD664D5EFDD1010F7E16F4 BROM : SecLevel : 0x000000E0 BROM : SecMode : EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 433AC99D583481A7B24993DD0F26EF7FB6EFD3B57ABD72CB6A 74C7E7BF717060 BROM : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Boot done! Done! Elapsed: 00:00:43 Reconnect Power/Cable! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM21) MODE : BOOTROM PORT : 21 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN RAPHAEL BROM : MEID : 864225C9FDBD664D5EFDD1010F7E16F4 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 433AC99D583481A7B24993DD0F26EF7FB6EFD3B57ABD72CB6A 74C7E7BF717060 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_1 EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Boot done! Done! Elapsed: 00:01:44 Reconnect Power/Cable! Any idea? Thanks! |
02-25-2021, 23:36 | #2 (permalink) |
Freak Poster Join Date: Mar 2011 Location: lagos nigeria
Member: 1535920 Status: Offline Thanks Meter: 31 | Do hardware report in service tab, then perform other operations. Sent from my Redmi Note 5 using Tapatalk |
The Following User Says Thank You to kazzy4real For This Useful Post: |
