05-31-2009, 11:58 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: HP Mnla,Philippines Age: 38
Member: 247410 Status: Offline Thanks Meter: 161 | >> Konka C623 Sim Blocked Done W/ Pinout Inside << Code: COM67 [VCP1] selected module v2.58 Action: read codes unlock method: read codes Model: Konka-C623 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A04:8A00]... CPU: MT6223 chip: 0011:43C8:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2005.07.11 Version: 1.0 Version: KAB623_JMA_En_Fr_Sp_1.01.A18 Version: KONKA23_07A_HW 44 byte(s) read imei: 35068630669380 connection Ok 157 byte(s) read Phone lock: Off Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 1234 Finished, time used: 17 sec Remove/Install battery now ! ==== log: [5/31/2009 6:16:34 PM] ==== COM67 [VCP1] selected module v2.58 Action: imei imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 350448011545453 Model: Konka-C623 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A04:8A00]... CPU: MT6223 chip: 0011:43C8:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2005.07.11 Version: 1.0 Version: KAB623_JMA_En_Fr_Sp_1.01.A18 Version: KONKA23_07A_HW 44 byte(s) read imei: 35068630669380 connection Ok 44 byte(s) read verification... verification done: 35044801154545 Finished, time used: 11 sec Remove/Install battery now ! ==== log: [5/31/2009 6:16:53 PM] ==== COM67 [VCP1] selected module v2.58 Action: read codes unlock method: read codes Model: Konka-C623 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A04:8A00]... CPU: MT6223 chip: 0011:43C8:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2005.07.11 Version: 1.0 Version: KAB623_JMA_En_Fr_Sp_1.01.A18 Version: KONKA23_07A_HW 44 byte(s) read imei: 35044801154545 connection Ok 157 byte(s) read Phone lock: Off Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 1234 Finished, time used: 12 sec Remove/Install battery now ! ==== log: [5/31/2009 6:17:12 PM] ==== COM67 [VCP1] selected module v2.58 Device: Konka-C623 Checking data, wait... advanced flash detection enabled Action: repair security area Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A04:8A00]... CPU: MT6223 chip: 0011:43C8:000C boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 921600 error: wrong answer: C3 error: can't work at this speed, use lower speed Set baud Fail Finished, time used: 8 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [5/31/2009 6:17:32 PM] ==== COM67 [VCP1] selected module v2.58 Action: reset settings Model: Konka-C623 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A04:8A00]... CPU: MT6223 chip: 0011:43C8:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2005.07.11 Version: 1.0 Version: KAB623_JMA_En_Fr_Sp_1.01.A18 Version: KONKA23_07A_HW 44 byte(s) read imei: 35044801154545 connection Ok building list... done items to clear: 168 warning: wrong packet cs items cleared: 168 of 168 building list... done items remains: 0 Finished, time used: 28 sec Remove/Install battery now ! ==== log: [5/31/2009 6:21:18 PM] ==== COM67 [VCP1] selected module v2.58 Action: imei imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 350448745757747 Model: Konka-C623 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A04:8A00]... CPU: MT6223 chip: 0011:43C8:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2005.07.11 Version: 1.0 Version: KAB623_JMA_En_Fr_Sp_1.01.A18 Version: KONKA23_07A_HW 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok 44 byte(s) read verification... verification done: 35044874575774 Finished, time used: 11 sec Remove/Install battery now ! ==== log opened: [5/31/2009 6:41:20 PM] ==== Application: C:\Program Files\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] v2.58 S/N: 260E:0112 Wait... Device: Aiko-17G Done Device: Konka-C623 WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [5/31/2009 6:42:24 PM] ==== COM67 [VCP1] selected module v2.58 Action: reset settings Model: Konka-C623 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A04:8A00]... CPU: MT6223 chip: 0011:43C8:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2005.07.11 Version: 1.0 Version: KAB623_JMA_En_Fr_Sp_1.01.A18 Version: KONKA23_07A_HW 44 byte(s) read imei: 35044874575774 connection Ok building list... done items to clear: 158 warning: wrong packet cs items cleared: 158 of 158 building list... done items remains: 0 Finished, time used: 35 sec Remove/Install battery now ! ==== log: [5/31/2009 6:45:56 PM] ==== COM67 [VCP1] selected module v2.58 Action: imei imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 350448088888885 Model: Konka-C623 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A04:8A00]... CPU: MT6223 chip: 0011:43C8:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2005.07.11 Version: 1.0 Version: KAB623_JMA_En_Fr_Sp_1.01.A18 Version: KONKA23_07A_HW 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok 44 byte(s) read verification... verification done: 35044808888888 Finished, time used: 11 sec Remove/Install battery now ! ==== log: [5/31/2009 6:47:20 PM] ==== COM67 [VCP1] selected module v2.58 Action: read codes unlock method: read codes Model: Konka-C623 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A04:8A00]... CPU: MT6223 chip: 0011:43C8:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2005.07.11 Version: 1.0 Version: KAB623_JMA_En_Fr_Sp_1.01.A18 Version: KONKA23_07A_HW 44 byte(s) read imei: 35044808888888 connection Ok 157 byte(s) read warning: wrong packet cs Phone lock: Off Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 1234 Finished, time used: 12 sec Remove/Install battery now ! ==== log: [5/31/2009 6:48:01 PM] ==== COM67 [VCP1] selected module v2.58 Action: unlock unlock method: smart fast Model: Konka-C623 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A04:8A00]... CPU: MT6223 chip: 0011:43C8:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2005.07.11 Version: 1.0 Version: KAB623_JMA_En_Fr_Sp_1.01.A18 Version: KONKA23_07A_HW 44 byte(s) read imei: 35044808888888 connection Ok 157 byte(s) read reading data... warning: wrong packet cs building new data... writing data... 145 byte(s) read reading data... building new data... writing data... verifying... verification Ok done Finished, time used: 12 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to jhepoy_org For This Useful Post: |
SRS Update 27-03-2010 >> Check Inside << | ssa | Service Products News & Updates | 0 | 03-27-2010 20:26 |
konka c623 succesfully unlocked ...but... | carlluvjo | Infinity-Box | 15 | 11-07-2008 17:23 |
26 Aug 2008: Spice-S705, BenQ-C30 added, Konka-C676, Konka-C623, Zonda-1095 in test | InfinitySupport | Infinity-Box | 9 | 08-29-2008 06:47 |
Infinity-Box: Spice-S705, BenQ-C30 added, Konka-C676, Konka-C623, Zonda-1095 in test | InfinitySupport | Service Products News & Updates | 0 | 08-26-2008 13:08 |
Please add support from Konka C623 (FM) | elcapitel | Infinity-Box | 9 | 08-11-2008 15:38 |
