Old 01-03-2009, 15:36   #1 (permalink)
zeel_zeel's Avatar
Member: 205427
Sonork: 100.1580937
Thanks Meter: 1,162
>>> Two SE J132 Unlocked OK <<<
Just unlocked 2 Sony Eric J132 (T-Mobile <> UK) with infinity box. Used LG C2500 com cable to unlock this phones. Even tried these phones with SE_Tool but could not succeed.
Thanks to Infinity Team >>>>>
module v1.30
Device: Sony-Ericsson-J132
"advanced chip detection" active
Action: unlock
Checking data, wait...
Boot ...
Press Power button now !
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Check connection ...
Check connection done
Set baud ...
115200
Set baud done
Check hardware ...
flash: 2088C0FFFFFFFF:2088C000000000
flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb
Check hardware done
Read data ...
reading Sony-Ericsson-J132_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20090103-172525.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 83 sec
Remove/Install battery now !
module v1.30
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Set baud ...
115200
Set baud done
Check hardware ...
Check hardware done
Read data ...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20090103-171521.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 80 sec
The Following User Says Thank You to zeel_zeel For This Useful Post:
Old 01-03-2009, 15:38   #2 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 213
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works and what is
possible problems (so we will be able to fix it) and successfully done work.
Old 01-03-2009, 16:53   #3 (permalink)
GMC
GMC's Avatar
Member: 14911
Thanks Meter: 13
COM6 selected
module v1.30
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot fail
error: operation failed
Finished, time used: 46 sec
Old 01-03-2009, 16:58   #4 (permalink)
alknadir's Avatar
Member: 59352
Thanks Meter: 50
COM3 [VCP0] selected
module v1.30
Périphérique: Sony-Ericsson-J132
"puce de détection avancée" active
Operation: déverrouiller
Contrôle des données, attendre ...
Boot ...
téléphone doit être éteint!
Appuyez sur bouton d'alimentation dès maintenant!
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Ensemble bauds ...
115200
Ensemble bauds done
Check hardware ...
Check hardware done
Read data ...
lecture Sony-Ericsson-J132_eeprom_calibration-1...
fichier sauvegardé: D:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20081225-162405.80E.bin
Read data done
Check data ...
Check data done
écrire ...
Ecris: simlock
écrire done
Terminé, temps utilisé: 75 sec
Retirez / remettre la batterie maintenant!
The Following User Says Thank You to alknadir For This Useful Post:
Old 01-03-2009, 16:59   #5 (permalink)
alknadir's Avatar
Member: 59352
Thanks Meter: 50
OM1 [Serial0] selected
module v1.30
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Ensemble bauds ...
115200
Ensemble bauds done
Check hardware ...
Check hardware done
Read data ...
fichier sauvegardé: D:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20081214-144640.80E.bin
Read data done
Check data ...
Check data done
écrire ...
Ecris: simlock
écrire done
Terminé, temps utilisé: 73 sec
Old 01-03-2009, 17:00   #6 (permalink)
alknadir's Avatar
Member: 59352
Thanks Meter: 50
COM1 [Serial0] selected
module v1.30
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Set baud ...
115200
Set baud done
Check hardware ...
Check hardware done
Read data ...
file saved: D:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20081126-164735.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 74 sec
Old 01-04-2009, 07:31   #7 (permalink)
zeel_zeel's Avatar
Member: 205427
Sonork: 100.1580937
Thanks Meter: 1,162
Originally Posted by GMC View Post
COM6 selected
module v1.30
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot fail
Mate you need to press power on button for a longer time....
Old 01-04-2009, 09:40   #8 (permalink)
Member: 265104
Sonork: 100.1609402
Thanks Meter: 88
thanks you brother
Old 01-15-2009, 19:15   #9 (permalink)
Member: 67584
Thanks Meter: 13
i have the same problem, can you help me plz?
Old 01-15-2009, 19:25   #10 (permalink)
Member: 67584
Thanks Meter: 13
Thank you friend, i tray but the same problem.
Old 01-15-2009, 23:22   #11 (permalink)
Member: 130995
Thanks Meter: 35,157
Hello,
It may be cable problem or problem with new hardware type (that is not supported yet).
At first try to make this:
>>> Two Lg Cu575 Unlocked 100% <<< keaelite LG 96 07-24-2011 07:57
Se j132 unlock ok allal123 Infinity-Box 19 01-03-2010 19:28
se j132 unlock ok with *******43 kaspersk SETool2 8 09-10-2009 01:29
>>> SE K660i (A2) Unlocked Ok <<< zeel_zeel SETool2 2 02-09-2009 10:29
>>> SE W380i Unlocked Ok <<< zeel_zeel SETool2 0 01-16-2009 15:04
Page generated in 0.20232 seconds with 9 queries
