03-03-2008, 08:28 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | uegent help need from team when i try to format this 2 error comes 1. COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled eeprom backup enabled, it may takes several minutes ! Action: reset enhanced security fix enabled Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb detecting chip #02 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb detecting chip #03 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb detecting chip #04 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb detecting chip #05 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb detecting chip #06 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb detecting chip #07 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud... slowest Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... error: wrong answer[3B] error: no any expected answer: wrong answer after chip id request error: no any expected answer error: no any expected answer: wrong answer after chip cfi request error: no any expected answer: wrong answer after chip id request number of flash chip/regions detected: 00/01 total flash region size: 00000000 detect device identification#1... detection phase #1... error: unexpected termination/freez: 00000000 detection phase #2... error: unexpected termination/freez: 00000000 warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... error: unexpected termination/freez: 00000000 warning: optional information not found detect device identification#2 finished error: autodetection failed Finished, time used: 74 sec Remove/Install battery now ! 2. COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset enhanced security fix enabled Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 error: wrong answer[3B]: wrong answer after chip cfi request error: no any expected answer: wrong answer after chip id request number of flash chip/regions detected: 01/01 Initialize Done Set baud... slowest error: can't work at this speed, use lower speed Set baud Fail Finished, time used: 20 sec Remove/Install battery now ! i also try to change budrate 1 by 1 but cant able to format plz any idea for me i m also tryt ountick advance chip detaction but not working for me |
03-03-2008, 09:57 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @joni_rajpura You have used wrong pinout. To repair "restart" problem you must format CPU-1 (master), but you have tried to format CPU-2 (slave). As about posted logs: you must use good cable based on FTDI chip or install good Prolific drivers (if you have used Prolific based cable). This problem with Prolific cables was described in this forum many times and you can read about this in FAQ thread ! http://67.15.194.130/vbb/showthread.php?t=476373 |
03-05-2008, 14:16 | #6 (permalink) |
No Life Poster Join Date: Aug 2002 Location: BULGARIA Age: 53
Member: 14868 Status: Offline Thanks Meter: 44 | I have problem for second SIM - "Slave initialing" - ZTC-k600 the phone came to me for restart problem - 1.formated CPU-1 (master) -> phone working but slave initialing. My question is can i format CPU-2 (slave) ? i have found that there is second pinout for second CPU but i received wrong information for that CPU |
help need from mt team | imran78669 | MT-BOX | 0 | 11-12-2009 07:05 |
urgent help needed from support team | alhajikoroma | Multi-box LITE | 1 | 09-15-2008 12:46 |
help needed from smartclip team pleasepleaseplease | branman5 | Smart-Clip | 1 | 08-21-2006 15:17 |
Help Needed From CRUISER TEAM | sallupat | Cruiser Suite | 0 | 08-14-2006 07:11 |
