12-23-2008, 10:58 | #1 (permalink) |
Major Poster Join Date: Apr 2008
Member: 759285 Status: Offline Thanks Meter: 4 | please help i am new please |
12-23-2008, 17:26 | #2 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
What phone you talk about ? I hope that you did not tried to use phone battery but you use PinFinder "Power" wires during connection. | |
12-24-2008, 08:24 | #3 (permalink) |
Member: 759285 Status: Offline Thanks Meter: 4 | You are really a Master i was using phone battery because the output voltage from the box was 4.83v and when connected to the pinfinder the power wires could not power phones. after a sometimes it show ...........error #1. please help |
12-24-2008, 18:47 | #4 (permalink) | |
Please, check PinFinder manual page-20, you will see an easy instruction how to fix problem with low voltage. | |
12-26-2008, 08:44 | #5 (permalink) |
Member: 759285 Status: Offline Thanks Meter: 4 | please i need advice from everyone my infinity pinfinder cant detect any pinout but the output voltage from the infinty box is 4.83v since it was not up to 5.0v i have to short circuit the diode as instructed in the manual but no way forward. Why? when i select pinout manually it says PRESS AND HOLD THE POWER BUTTON which i did for more than 30mins and it latter says CONNECTION ERROR #1 . WHY? |
12-29-2008, 12:51 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | @edos.harry Thank you very much for your total ignorance ! It is very good example of zero respect. yes, let's continue this way, let's ignore questions and advices: http://forum.gsmhosting.com/vbb/show...59&postcount=6 |
12-30-2008, 10:44 | #9 (permalink) |
Member: 759285 Status: Offline Thanks Meter: 4 | with due respect i accept i all faults because i am new to this infinity box. it was configuration problem a friend has com to fix everything all is working now thanks for your contribution and advice |
12-30-2008, 11:12 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, We are very glad to see that your problem was solved. Anyway, if you want to fix and possible problems with PinFinder you must check voltage at unibox pin-1 as a first step. |
I am new...Please help with Flash!!!! | tommyvo | Cyclonebox | 10 | 06-13-2009 05:56 |
please i need help i am new user | masad | UST Pro II | 2 | 11-28-2007 12:41 |
HWK Killer Please Help I Am New To UFS 3 | mobilelatham | UFS2 + UFS3-Tornadoflasher | 1 | 07-03-2007 10:18 |
K300 error HELP!!!! i am new at this....thanks | Maykoid | SonyEricsson (USB-Smart) | 7 | 02-07-2006 06:10 |
Help i am new | buha | Sim Cloning and Scaning | 4 | 07-17-2003 10:57 |
