Old 09-19-2015, 21:44   #1 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,450
RDA Bug Found
RDA Android Handset Flash Not Start Only Waiting But Done With Factory Tool Kindly Fix It
Test on Windows 8.1 64Bit
Mobile Brand Name : Spice
Model :Mi-347
=========================Start==================== =====
13-09-2015 / 15:09:38
Card found: S/N
Chinese Miracle II [RDA module] v 1.02
Load file...
RDATotal : Spice_Mi-347_IND_Ver2.0_20141101_rda_total.bin
Load Ok
Start at : [13-09-2015 / 15:11:01]
Operation : Flash
======= Settings
Settings : Factory Settings Enabled
======= Flash
Files set for flashing :
RDATotal File : Spice_Mi-347_IND_Ver2.0_20141101_rda_total.bin
Load Ok : PDL1
Load Ok : PDL2
Load Ok : bootloader
Load Ok : boot
Load Ok : system
Load Ok : modem
Load Ok : customer
Load Ok : recovery
Waiting phone ...
Connect battery, press and hold 'VolUP' + 'PowerOn' buttons
Connect USB cable and keep hold buttons, until phone will be detected
As You Told Me Before To Post PID & CID So Here IT IS
Kindly Fix IT ASAP.
About MTK & SPD (Bugs) Which I Was Told You Soon I Will Post Now Days Not Getting Time Busy With Work This Report Also Taken Few Days Back.
Brother Don't Consider As SPAM Genuine Report You Can Check Also If U Want. Test On Windows 8.1 64Bit
Old 09-19-2015, 21:52   #2 (permalink)
Member: 1834832
Thanks Meter: 1,450
24-08-2015 / 02:42:33
Card found: S/N
Load file...
RDATotal : UTLA109v1011_rda_total.bin
Load Ok
Start at : [24-08-2015 / 02:43:34]
Operation : Flash
======= Settings
======= Flash
RDATotal File : UTLA109v1011_rda_total.bin
Load Ok : PDL1
Load Ok : PDL2
Load Ok : boot
Load Ok : system
Load Ok : modem
Load Ok : customer
Load Ok : recovery
Waiting phone ...
From Old History Same Issue (Which Was Reported Before Also)
Phone Brand Karbonn
Model A109
I Know & Check Your Success History With This Model But Not Success In My May Be New VID PID Or OS Issue..
Old 09-20-2015, 05:02   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello. Problem in administrator rights and some ports enumeration.
Will be fixed in V1.03.
Old 09-20-2015, 11:04   #4 (permalink)
Member: 1834832
Thanks Meter: 1,450
Already Running With Admin Rights Bro....
Old 09-20-2015, 13:35   #5 (permalink)
JayDi's Avatar
Member: 462970
I made some changes. Should work now.
At least - it work on my Win8.1 x64 as should
CM2RDA - Download - 4shared
The Following 2 Users Say Thank You to JayDi For This Useful Post:
Old 09-20-2015, 13:39   #6 (permalink)
Member: 1834832
Thanks Meter: 1,450
Thanks Brother But Now No Phones In Hand For Service Soon Or Let Me Try To Arrange & Check...
The Following User Says Thank You to hitech care For This Useful Post:
Page generated in 0.13323 seconds with 8 queries
