Old 02-08-2011, 18:37   #1 (permalink)
bencebacsi's Avatar
Member: 829361
Thanks Meter: 107
Alcatel OT-806
Infinity CM can not read this flash. This is a good working phone.
COM16 [VCP2] selected
module v3.26
Device: Autodetect 6228-6253 NAND
Checking data, wait...
Action: read flash NAND
interface: BROM_DLL_v3.1016.00
Connect...
bootcode current/expected: 0.0/3.2
CPU: 6235:8A04:8A01
status: 02
bbchip bl ver: FE
NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D
chip size: 0Mb
otp status/size: S_DONE/00000000
NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C
chip size: 0Mb
page/spare size: 0000/0000
pages per block: 0000
bits i/o: 00
address cycles: 00
internal RAM size: 00000000
external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000
sec error code: AA
error: can not boot device: 1772:S_SECURITY_SLA_INVALID_AUTH_FILE
error: last error: 1772:S_SECURITY_SLA_INVALID_AUTH_FILE
Disconnect...
done
Finished, time used: 8 sec
Remove/Install battery now !
Old 02-13-2011, 13:52   #2 (permalink)
bencebacsi's Avatar
Member: 829361
Thanks Meter: 107
Up!.................
Old 02-13-2011, 14:01   #3 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
module v3.26
Connect...
CPU: 6235:8A04:8A01
status: 02
bbchip bl ver: FE
chip size: 0Mb
chip size: 0Mb
bits i/o: 00
address cycles: 00
sec error code: AA
Disconnect...
done
This model is supported ?
If your Mobile is working then infinity cant read the Flash IC
There is several coz
Old 02-13-2011, 20:17   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
we are working under this problem
Old 06-01-2011, 15:23   #5 (permalink)
Member: 104946
Thanks Meter: 33
ANOTHER ONE OT-806 in same condition
COM36 [VCP2] selected
module v3.31
Device: Autodetect 6205-6239 NOR
Action: read/check information
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6235:8A04:8A01]...
CPU: MT6235
high speed boot On
chip: 0000:0000:8003
status: 02
boot packet size: 0400
error: bootcode start error: A4 not authorized: 000000A4
Release Power button now !
Boot Done
====> Initialize ...
error: no any expected answer : wrong answer after chip cfi request
number of flash chip/regions detected: 00/01
flash chip is unknown or damaged.
Fault reasons:
1. unknown hardware: contact to support: [email protected]
2. hardware is damaged: check hardware, water inside etc.
Initialize Fail
Finished, time used: 31 sec
I removed the metallic shield over flash an d mcu
FLASH MODEL : ST : NAND A 9W3N6
CZBB5 HO 6A012 80
CHN 99 028
MCU :MEDIATEK MT6235 BSA
i re-hot the mcu +flash but the result log is the same at before. Pin-out connected as alcatel C701. The phone is very clean no other broken hardware is visible and no water inside.
Old 06-01-2011, 15:28   #6 (permalink)
Member: 104946
Thanks Meter: 33
Model: Autodetect 6205-6239 NOR
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6235, E04
Hardware version: JRD35_09B_HW
Software version: MAUI.09B.W09.52.SP1.
Software date: 2000.00.00
Barcode: MT01234567890123xxxx
imei-1: 35263304007xxxx
Finished, time used: 18 sec
Old 06-01-2011, 15:53   #7 (permalink)
Member: 104946
Thanks Meter: 33
module v3.31
Device: Autodetect 6228-6268 NAND
Action: read firmware NAND
Connect...
CPU: 6235:8A04:8A01
status: 02
bbchip bl ver: FE
chip size: 0Mb
chip size: 0Mb
bits i/o: 00
address cycles: 00
sec error code: AA
Disconnect...
done
Old 06-02-2011, 23:11   #8 (permalink)
Member: 104946
Thanks Meter: 33
Hello again! When will add INFINYTY SUPPORT TEAM this model? OT-806 ?
Old 09-01-2011, 08:44   #9 (permalink)
Crumarix1's Avatar
Member: 84300
Thanks Meter: 74
Still not suported !!!!!
I need flash to Alcatel One Touch Viev db: Be 3, 2 mb,16A sosin Alcatel & TCL Old Models 0 02-13-2002 03:47
Alcatel BE$ pinouts GSM Coolhawk Alcatel & TCL Old Models 0 12-08-2001 15:44
NOKIA, ALCATEL EEprom site Orbital - GSM GSM Mobile Links 0 04-09-2001 10:31
Alcatel One Touch cable needed!!! tati Alcatel & TCL Old Models 0 05-17-1999 22:05
Page generated in 0.22996 seconds with 9 queries
