03-24-2009, 15:49 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Made In Brazil Age: 42
Member: 264903 Status: Offline Sonork: 1584531 Thanks Meter: 3,350 | unlock 100% ZTE X760 ==== Log: [24/3/2009 11:39:51] ==== COM9 [Serial2] selected Module v2.68 Action: Unlock Method of releasing: Intelligent Model: ZTE-X761 Checking Data. Wait ... The phone should be off! Press and hold the Connect button! 19200 autodetect Initializing [6225:8 A03: 8A00] ... CPU: MT6225 chip: 0001:7 C03: 000E status: FF Connecting at 19,200, wait ... Release the button to Connect! Phone Found. Wait ... Hardware: MT6225, E03 Date: 2006.06.14 Version: 1.0 Version: X760_Z1_P_B07A108 Version: ZTEMT25_07A_HW_E 44 byte (s) read IMEI: 35235302946618 Connected 157 byte (s) read Reading data ... reading data # 2 ... Building New Data ... Writing data ... 145 byte (s) read Reading data ... Building New Data ... Writing data ... Verifying ... Checking Made Finalized. Time Spent: 14 sec Remove / Replace the battery! |
The Following 14 Users Say Thank You to LuisinhoCell For This Useful Post: |
03-24-2009, 16:03 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Thanks a lot for information ! Please, read full flash from X760 and send full flash backup to [email protected] |
03-24-2009, 18:09 | #3 (permalink) | |
Member: 264903 Status: Offline Sonork: 1584531 Thanks Meter: 3,350 | Quote:
ok.................... | |
The Following User Says Thank You to LuisinhoCell For This Useful Post: |
04-13-2009, 06:49 | #4 (permalink) |
Freak Poster Join Date: Dec 2007 Location: Land of Promise
Member: 659309 Status: Offline Thanks Meter: 121 | hello mate i have this unit ZTE X760 succesfully unlock T-mobile heres the logs.... COM64 [VCP1] selected module v2.69 Action: unlock unlock method: smart fast Model: ZTE-X760 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001103:0001 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: X760_Z10UK_GD_B07A104 Version: ZTEMT25_07A_HW_C 44 byte(s) read imei: kingskie connection Ok 157 byte(s) read reading data... warning: wrong packet cs building new data... writing data... 145 byte(s) read reading data... building new data... writing data... verifying... verification Ok done Finished, time used: 10 sec Remove/Install battery now ! pinout same like x761.... done.. kingskie.. |
The Following 18 Users Say Thank You to kingskie For This Useful Post: |
05-05-2009, 21:05 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @torrescellgsm Are you sure that you have made your post in correct forum section ? |
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post: |
05-06-2009, 12:57 | #9 (permalink) |
Junior Member Join Date: Nov 2006 Location: UK (Leeds)
Member: 400999 Status: Offline Thanks Meter: 2 | Is this done via the usb cable that comes with the phone or will i need a speciealist cable? |
The Following User Says Thank You to supercat For This Useful Post: |
05-06-2009, 19:38 | #11 (permalink) | |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 | |
The Following 4 Users Say Thank You to InfinitySupport For This Useful Post: |
05-09-2009, 19:09 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @karabey please, read full flash from this phone and send to us full flash but not only eeprom: [email protected] |
05-14-2009, 00:33 | #14 (permalink) |
Freak Poster Join Date: Aug 2005 Location: Kingston Age: 46
Member: 166442 Status: Offline Thanks Meter: 26 | ZTE X760 succesfully unlock T-mobile COM4 [VCP0] selected module v2.73 Action: unlock unlock method: smart fast Model: ZTE-X760 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:7703:0001 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: X760_Z10UK_GD_B07A104 Version: ZTEMT25_07A_HW_C 44 byte(s) read imei: 35235302061594 connection Ok 157 byte(s) read reading data... building new data... writing data... 145 byte(s) read reading data... building new data... writing data... verifying... verification Ok done Finished, time used: 11 sec Remove/Install battery now ! |
The Following 4 Users Say Thank You to kingsat100 For This Useful Post: |
05-31-2009, 16:14 | #15 (permalink) |
No Life Poster Join Date: Jun 2004 Location: China Age: 46
Member: 68392 Status: Offline Sonork: 100.100701 Thanks Meter: 658 | COM5 [VCP0] selected module v2.75 Action: unlock unlock method: smart fast Model: ZTE-X760 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:C203:0006 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: X760_Z10UK_GD_B07A104 Version: ZTEMT25_07A_HW_C 44 byte(s) read imei: 35235302059159 connection Ok 157 byte(s) read reading data... reading data #2... building new data... writing data... 145 byte(s) read reading data... building new data... writing data... verifying... verification Ok done Finished, time used: 14 sec Remove/Install battery now ! |
The Following 6 Users Say Thank You to Kanwalgee For This Useful Post: |
Please help me unlock a ZTE x760 | breztt | Phone Unlocking Codes & Maps | 7 | 12-15-2012 22:34 |
Unlock ZTE X760 100% MasterBox | LuisinhoCell | Mastertools | 5 | 01-01-2010 09:36 |
Strange problem after unlock with zte x760 | chowdary | Infinity-Box | 5 | 09-23-2009 17:26 |
Zte x760 unlock 100% !! | Umbabaraumba | Infinity-Box | 0 | 06-27-2009 11:06 |
