12-27-2017, 19:15 | #1 (permalink) |
Freak Poster Join Date: Jul 2009 Location: In The World
Member: 1068286 Status: Offline Thanks Meter: 182 | Unlock BootLoader Not Supported ! Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! Operation : FastBoot : ReadInfo [ v1.58 ] Power Off Phone , re-connect battery , Insert USB cable! Wait for phone... Phone found! [ 21 ] Sync... Protocol : 0.5 Device : AL827 Storage : eMMC BootLoader : Locked Warranty : Not tampered ( Under Warranty ) Secure : Enabled ExtraStat : FB Load Supported! Done! Elapsed: 00:00:12 Reconnect Power/Cable! Operation : FastBoot : Unlock BootLoader [ v1.58 ] Power Off Phone , re-connect battery , Insert USB cable! Wait for phone... Phone found! [ 21 ] Sync... Protocol : 0.5 Device : AL827 Storage : eMMC BootLoader : Locked Warranty : Not tampered ( Under Warranty ) Secure : Enabled ExtraStat : FB Load Supported! Boot Unlock/Relock init failed! Operation NOT SUPPORTED! Operation Failed Elapsed: 00:00:24 Reconnect Power/Cable! |
12-28-2017, 02:22 | #3 (permalink) | |
Member: 1068286 Status: Offline Thanks Meter: 182 | Quote: Thank you for reply but this solution not work Operation : FastBoot : Unlock BootLoader [ v1.58 ] Power Off Phone , re-connect battery , Insert USB cable! Wait for phone... Phone found! [ 21 ] Sync... Protocol : 0.5 Device : AL827 Storage : eMMC BootLoader : Locked Warranty : Not tampered ( Under Warranty ) Secure : Enabled ExtraStat : FB Load Supported! Boot Unlock/Relock init failed! Operation NOT SUPPORTED! Operation Failed Elapsed: 00:00:14 Reconnect Power/Cable! Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 39 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 484A0190613447414433D432A728A220 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! | |
12-28-2017, 07:38 | #4 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
Also mention ur device name | |
