11-04-2016, 13:32 | #5 (permalink) |
Major Poster Join Date: Jun 2016
Member: 2582161 Status: Offline Thanks Meter: 2 | sc7731g modem sc8830 unlock error Reconnect Power/Cable! Finish at : [30/10/2016 / 10:08:01] Start at : [30/10/2016 / 10:08:27] Operation : Check/Read Info [ v1.22 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 23 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! |
11-04-2016, 15:31 | #10 (permalink) |
Freak Poster Join Date: Aug 2010 Location: (United States Of Islam) dz
Member: 1364507 Status: Offline Sonork: (United States Of Islam) Thanks Meter: 81 | . Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 23 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! IN WIN7 |
11-05-2016, 14:18 | #11 (permalink) |
Crazy Poster Join Date: Jul 2010
Member: 1340219 Status: Offline Thanks Meter: 25 | boot fail ==== Wait for phone... Phone found! [ 40 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! |
11-05-2016, 17:08 | #14 (permalink) | |
Insane Poster Join Date: Dec 2014
Member: 2309061 Status: Offline Thanks Meter: 10 | Quote:
Code: Chinese Miracle II [SPD module] v 1.22 Operation : SP Unlock [ v1.22 ] Mode : DirectUnlock 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 16 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! | |
11-05-2016, 17:12 | #15 (permalink) |
Member: 2309061 Status: Offline Thanks Meter: 10 | Code: Operation : Check/Read Info [ v1.22 ] 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Phone Initial Info : Platform : MOCORTM_14B_7731C_W16.09.2_Debug Project : sc7731g_CP0_modem HWInfo : sc7731g_CP0_modem Compile : 02-19-2016 17:07:00 Phone Security Info : IMEI [1] : 3582510712xxxxx IMEI [2] : 3582510713xxxxx BT_ADDR : 000000000000 SelfInfo : BatVoltage : 3.947 V Done Reconnect Power/Cable! |
