02-11-2010, 20:05 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | Simoco sm-999 new firmware detected> READED OK SET LOG:- Code: COM3 [VCP0] selected module v3.08 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:35C0:1C18 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.89E38348.[M500TV_Y153PA2052_PCB01_GPRS_MT6226_S01.00_0.BIN_E24EBF3F].rpl rom info detection finished ==================== New firmware detected (v.3.08, database date: unknown): M500TV_Y153PA2052_PCB01_GPRS_MT6226_S01.00_0.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: 89E38348 rom info ver: 04 sw version: M500TV_Y153PA2052_PCB01_GPRS_MT6226_S01.00_0.BIN project-id: M500TV_Y153PA2052.00.0, 3FBF4EE2 code offset: 00000000 ffs offset/size [01]: 00800000/001FF000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area [00000000]: 00080000-00FFFFFF... ffs/eeprom found near: 00E00000 Detected ffs/eeprom address is non-standard: 00E00000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: M500TV_Y153PA2052_PCB01_GPRS_MT6226_S01.00_0__fullflash... file saved: C:\Program Files\InfinityBox\ChineseMiracle\M500TV_Y153PA2052_PCB01_GPRS_MT6226_S01.00_0__fullflash_20100212-002259.B0M SIMOCO SM-999 file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\M500TV_Y153PA2052_PCB01_GPRS_MT6226_S01.00_0__system_log_89E38348_E24EBF3F_20100212-002608.B0X.bin Finished, time used: 15 min 3 sec Remove/Install battery now ! HEARE IS FILE== |
The Following User Says Thank You to debmobile For This Useful Post: |
Simoco sm-499 new firmware detected> | debmobile | Infinity-Box | 2 | 02-19-2010 12:57 |
Heare is simoco sm-324 new firmware detected | debmobile | Infinity-Box | 5 | 12-20-2009 16:47 |
<new model simoco sm-1200 new firmware detected> | debmobile | Infinity-Box | 3 | 12-07-2009 09:02 |
Simoco sm-399 new firmware detected | debmobile | Infinity-Box | 2 | 07-31-2009 17:20 |
Simoco Sm-498 New Firmware Detected. | debmobile | Infinity-Box | 3 | 08-08-2008 10:49 |
