08-02-2016, 13:34 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | unlock huawei y336-u02 Card found: S/N : A6C080ED , v0132 Chinese Miracle II [SPD module] v 1.20 Operation : SP Unlock [ v1.20 ] Mode : DirectUnlock 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 134 ] Open Port Failed! Reconnect Power/Cable! Operation : SP Unlock [ v1.20 ] Mode : DirectUnlock 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 488 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! |
08-03-2016, 11:21 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. 1. It secured phone. You must select secure boot. 2. They are not locked in normal way. They customized for some ServiceProviders. You need try other FW versions. |
