09-15-2010, 20:31 | #1 (permalink) |
No Life Poster Join Date: Apr 2010 Location: France Age: 47
Member: 1285915 Status: Offline Thanks Meter: 35 | Unlock OT-505 failed I can't unlock Alcatel ot-505. What's the problem with it ? Can you help me, please ? ---------------------------------------------------------------------- COM46 [VCP0] selected module v3.03 Action: read unlock codes unlock method: read codes Model: Aiko-17G Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:A3D6:A00C status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: MAUI.08A.W08.36.SP1.V34 Version: JRD23_08A_HW 72 byte(s) read imei: 14C636164756C6 connection Ok 77 byte(s) read reading data #2... reading data #3... reading data #4... reading data #5... 32 byte(s) read error: source data size is less than expected error: operation failed ! Finished, time used: 36 sec Remove/Install battery now ! -------------------------------------------------------------------- Thanks to all. |
09-16-2010, 09:41 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | oops!! wrong model selected i think you want to kill the preety set select correct model than do the job |
The Following User Says Thank You to maplegsm For This Useful Post: |
09-16-2010, 10:13 | #3 (permalink) |
Registered User Join Date: Jul 2006 Location: phillippines
Member: 321917 Status: Offline Thanks Meter: 19 | COM46 [VCP0] selected module v3.03 Action: read unlock codes unlock method: read codes Model: Aiko-17G (select ot 505 sir ) |
The Following User Says Thank You to adjibt For This Useful Post: |
09-16-2010, 14:39 | #7 (permalink) |
Member: 1285915 Status: Offline Thanks Meter: 35 | And i forgot : in my infinity shell, after selected 505X, it was this on the left, and nothing on the right : ---------------------------------------------------------- Information is not found in database, see more here: 1. C:\Program Files\InfinityBox\pinout\ 2. C:\Program Files\InfinityBox\pinout\ChineseMiracle\ --------------------------------------------------------- Is this normal ? |
09-17-2010, 11:21 | #9 (permalink) |
No Life Poster Join Date: Dec 2005 Location: algeria
Member: 206173 Status: Offline Thanks Meter: 169 | hello , u have to re install the last mmodule download and install mmodule and then u find the phone model and do unlock, i juste unlocked one ot505 COM6 [VCP0] selected module v3.54 Device: Alcatel-505X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:B910:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [protected] type, 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.EFEF4 E70.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_59B64033].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: EFEF4E70 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 3340B659 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 268 provider: 505X-2ASFFR1 customization: CP26CQ24 customization: XP26CQ24 TCL-ID identification done rom info structure: 2nd [protected] type, 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XP26CQ24 customization name adjusted flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: EC240200000000:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-505X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V34__system_log_EFEF4E70_59B64033_20100917-111133.B0X.bin Finished, time used: 3 min 28 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 2 Users Say Thank You to yahia ali For This Useful Post: |
09-18-2010, 00:01 | #10 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,936 | Quote:
Just visit support area and download and install latest MModule software update. Latest MModule v3.59. I strongly suggest you do not use half year old software. | |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
