12-20-2008, 23:05 | #1 (permalink) |
Major Poster Join Date: Dec 2007
Member: 658225 Status: Offline Thanks Meter: 4 | unlock lg mg-160a, as I do? I made the 2 methods sp-unlock and in the end not unlock I also flasheado the last Comcel the phone is mg160a, Telcel mexico please which use flash, or that method help |
12-20-2008, 23:18 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, try to unlock phone by all possible methods. In case of any problems please post here operation log so we will be able to check it. |
12-20-2008, 23:51 | #3 (permalink) |
Member: 658225 Status: Offline Thanks Meter: 4 | hello Here post results COM46 [VCP0] selected module v1.55 Device: LG-MG160 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: ULC2GL Central AM II MG160aP16FL AM_MD2 V09b XXX-XX Mar 28 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-sta... file saved: C:\Program Files\InfinityBox\Pana01\LG-MG160_eeprom-sta_20081220-164139.B1E.bin loading data... data loaded imei: 01146400406462700 reading eeprom-sec_01146400406462700... file saved: C:\Program Files\InfinityBox\Pana01\LG-MG160_eeprom-sec_01146400406462700_20081220-164143.B1E.bin reading eeprom-complete_01146400406462700... file saved: C:\Program Files\InfinityBox\Pana01\LG-MG160_eeprom-complete_01146400406462700_20081220-164151.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-sec Writing: eeprom-sec probably you need to restore original imei after unlock process Write Done Finished, time used: 30 sec Remove/Install battery now ! results sim lock COM46 [VCP0] selected module v1.55 Device: LG-MG160 Checking data, wait... Action: unlock read unlock codes Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: ULC2GL Central AM II MG160aP16FL AM_MD2 V09b XXX-XX Mar 28 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-sta... file saved: C:\Program Files\InfinityBox\Pana01\LG-MG160_eeprom-sta_20081220-164557.B1E.bin loading data... data loaded imei: 01146400406462700 reading eeprom-sec_01146400406462700... file saved: C:\Program Files\InfinityBox\Pana01\LG-MG160_eeprom-sec_01146400406462700_20081220-164601.B1E.bin reading eeprom-complete_01146400406462700... file saved: C:\Program Files\InfinityBox\Pana01\LG-MG160_eeprom-complete_01146400406462700_20081220-164608.B1E.bin backup critical area Done Check memory ... loading data... data loaded code: 67589802 Finished, time used: 27 sec Remove/Install battery now ! results sim lock yet COM46 [VCP0] selected module v1.55 Device: LG-MG160 Checking data, wait... Action: unlock direct unlock method #1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: ULC2GL Central AM II MG160aP16FL AM_MD2 V09b XXX-XX Mar 28 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-sta... file saved: C:\Program Files\InfinityBox\Pana01\LG-MG160_eeprom-sta_20081220-164829.B1E.bin loading data... data loaded imei: 01146400406462700 reading eeprom-sec_01146400406462700... file saved: C:\Program Files\InfinityBox\Pana01\LG-MG160_eeprom-sec_01146400406462700_20081220-164831.B1E.bin reading eeprom-complete_01146400406462700... file saved: C:\Program Files\InfinityBox\Pana01\LG-MG160_eeprom-complete_01146400406462700_20081220-164839.B1E.bin backup critical area Done Check memory ... loading data... data loaded loading data... data loaded loading data... data loaded loading data... data loaded code: 67589802 error: not locked or unknown eeprom Check memory Failed Finished, time used: 26 sec Remove/Install battery now ! I can tell you please use that method, or through flash, which I use for fvaor thanks best regards |
12-21-2008, 10:05 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Did you tried to enter unlock code ? 1. Make "read unlock codes" 2. Power-On phone with accepted SIM card 3. Type: 2945#*20001# 4. MENU -> SETTINGS (5) -> SECURITY (7) -> (6) -> (1) -> OK -> enter unlock code |
01-04-2009, 13:13 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, try to flash phone with this MG160aP16-593-V10a-740-XX-May-10-2007+5_firmware_lp_without_logo.B1M.bin or this MG160aP16FL-AM_MD2-V09b_000-00_Mar-28-2007+0_Central-AM-II_firmware_lp.B1M.bin file and see results. |
01-08-2009, 15:47 | #11 (permalink) |
Banned Join Date: Oct 2005 Location: www.cilianunlock.com
Member: 194420 Status: Offline Thanks Meter: 15 | MG160aP16FL_AM_MD2-V09b_XXX-XX_Mar-28-2007+0_firmware[1].B1M MG160aP16FL_AM_MD2-V09b_XXX-XX_Mar-28-2007+0_LP_En_Es_Colombia[1].B1P MG160_file_system_dffs_reset_defaults_and_user_cod e[1].B1S |
The Following User Says Thank You to cilian For This Useful Post: |
01-08-2009, 15:48 | #12 (permalink) |
LG MG-160a unlock problem | audiovisual | VygisToolbox | 10 | 09-26-2008 02:12 |
Unlock LG MG 295d with whats cable ? | Paul Guaņuna | FuriousGold | 4 | 12-17-2007 09:38 |
Unlock LG MG 220d, 230d | Paul Guaņuna | FuriousGold | 2 | 12-13-2007 13:18 |
need help unlock lg mg 191 with blazer box | jakerxp | LG | 1 | 06-20-2007 19:36 |
any free soft for unlock lg mg 191 | mike_570 | LG | 0 | 01-11-2006 06:02 |
