06-28-2008, 09:45 | #1 (permalink) |
Insane Poster Join Date: Jan 2007 Location: philipines
Member: 437258 Status: Offline Thanks Meter: 23 | unlock myphone S21??? . . . Tx Rx none ground will connected to - supply logs: COM30 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: unlock unlock method: standard Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:4FCB:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.5958231F.[TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W0736 _MP_FMCAM-FTP_V0_07.BIN_85FEEF84].rpl ==================== New firmware detected: TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W0736 _MP_FMCAM-FTP_V0_07.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 5958231F identification#1 protocol ver: 04 ver. sw1: TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W0736 _MP_FMCAM-FTP_V0_07.BIN ver. sw2: T01_23.07A.W0736.MP.FMCAM-FTP_V0.07, 7B10017A ffs offset/size: 00800000/00800000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: 01227E22202200:2AEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00A40000 Detected eeprom/ffs address is non-standard: 00A40000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00A40000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 005C0000 ffs chip: 00 eeprom/ffs area: 00000000:00A40000-00FFFFFF detecting ffs structure pass 1... ...................... detect standard fat location pass #1... ......................................... detect extended fat location pass #1... ............................. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W0736 _MP_FMCAM-FTP_V0_07.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W0736 _MP_FMCAM-FTP_V0_07.BIN]_20080627-183424.B0E.bin flash: 01227E22202200:2AEA0000000000 Backup required data Done Patch required data... detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Fail file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_595823 1F_TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W0 736_MP_FMCAM-FTP_V0_07.BIN_85FEEF84_20080627-183431.B0X.bin Finished, time used: 659 sec Remove/Install battery now ! but unlock not done,, any suggestion? thanks, yhob |
06-28-2008, 09:51 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, 1. Code: ==================== New firmware detected: TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W0736 _MP_FMCAM-FTP_V0_07.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== |
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post: |
06-29-2008, 11:45 | #5 (permalink) | |
Freak Poster Join Date: Apr 2006 Location: Philippines
Member: 257511 Status: Offline Thanks Meter: 69 | Quote:
hi sir, i also have here one, need to be unlock, after successfull unlock in soft still locked...only provider sim is accepted, if i insert another sim it displays INSERT SIM, i tried also format ffs up to format ffs whole flash chip, now phone is dead i only back up eeprom file. can you please upload full flash so that i can revive it again. thanks in advance. br | |
06-29-2008, 11:55 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @Brod Aries It was little bit not smart move to make "format whole flash chip" without full flash backup. We can not upload any files for this phone yet due to we did not received any full flash readed from good working phone. Also if you see at phone LCD text like "INSERT SIM" this means that phone is not locked but phone can not work with your sim card type due to hardware limitations. There is a very small chance that it's rare type of phone protection, but we have no chance to check it untill we will get full flash backup from good working phone. [email protected] |
06-29-2008, 12:17 | #7 (permalink) | |
br | |
06-30-2008, 04:04 | #10 (permalink) | |
Freak Poster Join Date: Nov 2005 Location: Manila
Member: 198113 Status: Offline Sonork: 100.161124 Thanks Meter: 95 | Quote:
sir i have fullflash for this phone, but i dont know how to upload it | |
06-30-2008, 16:07 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Backup files received, files will be uploaded in support area and this model will be added ASAP. |
>>> MyPhone S21 successfully unlocked and pinout here <<< | keaelite | Infinity-Box | 39 | 10-18-2009 05:37 |
myphone s21 unlock atlast...... | jaburnok | Infinity-Box | 11 | 07-31-2009 09:56 |
myphone s21 unlock bugs | jaburnok | Infinity-Box | 3 | 08-17-2008 12:49 |
myphone s21 unlock not done | tahod | Infinity-Box | 5 | 07-03-2008 10:59 |
Myphone S21 How to Unlock? | ASHRIFF | Infinity-Box | 1 | 06-04-2008 11:44 |
