06-24-2011, 09:17 | #1 (permalink) |
No Life Poster Join Date: Dec 2008 Location: some were in my head Age: 42
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks Meter: 119 | unlock ot 355 100% module v3.94 Device: Alcatel-355X, 355A, 355DA Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:B963:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: D:\InfinityBox\MModule\backup_security\id.ECDF4970 .[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_F63A8537].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: ECDF4970 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 37853AF6 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 46I provider: 355X-2DRGFR1 customization: CI46CBA2 customization: XI46CBA2 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XI46CBA2 customization name adjusted flash: 01227E22202200:2BEA0000000000 flash: 01227E22202200:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E22202200:2BEA0000000000 flash: 01227E22202200:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35392304437978 flash: 01227E22202200:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22202200:2BEA0000000000 Finalization Done file saved: D:\InfinityBox\MModule\backup_security\Alcatel-355X,355A,355DA_JRD23_08A_PCB01_GPRS_MT6223P_S00.M AUI_08A_W08_36_SP1_V34__system_log_ECDF4970_F63A85 37_20110624-091003.B0X.bin Finished, time used: 4 min 46 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
06-24-2011, 19:32 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. |
08-11-2011, 11:25 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | For newest Alcatel models (f.e. 203, 708, V541 etc.) that freez/reboot after sp-unlock: 1. use "MModule" software v3.22 or newer 2. use "Write" button from software "Service" page and write original imei (from phone back label) 3. make "sp-unlock" |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
