08-13-2022, 10:09 | #1 (permalink) |
Freak Poster Join Date: May 2016
Member: 2573102 Status: Offline Thanks Meter: 21 | Zte! dead after flash with Sp flashtool! Emmc read write was ok~! flashing failed on 33% at system.img now enable Dram failed! when i try to init preloader with tools! it says preloader doesn't support this eMMC Not! Supported HW by Preloader : FlashID [0] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] FlashID [1] CID : 45010053454D303447 , Name : SEM04G , Vendor : 45 , [SANDISK] FlashID [2] CID : 1501004E35585A4D42 , Name : N5XZMB , Vendor : 15 , [SAMSUNG] FlashID [3] CID : 45010053454D303447 , Name : SEM04G , Vendor : 45 , [SANDISK] FlashID [4] CID : FE014E503058585858 , Name : P0XXXX , Vendor : FE , [MICRON] FlashID [5] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A18474714F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] can someone please confirm that this preloader support this eMMC or not! Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040501A18474714F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A18474714F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x6DF22C9FD4BDB2DC8490DC661B75A8E8 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Processing] FlashMemory Read-Write test [eMMC] : [HYNIX] , d1G4 , 0xE9000000 , 3728 MiB [eMMC] : CID : 90014A4834473164040501A18474714F [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! |
08-13-2022, 11:46 | #2 (permalink) |
Member: 2573102 Status: Offline Thanks Meter: 21 | Init preloader failed! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 65646F4D204D4F52128100000615444D [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND Firmware selected, but it NOT compatible! Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! Finish at : [8/13/2022 / 2:40:03 PM] |
08-13-2022, 17:43 | #4 (permalink) |
Member: 2573102 Status: Offline Thanks Meter: 21 | Sir! i have provided the log of EMMC test and Init preloader ! flash log log isn't there because i used sp flash tool to flash the phone ! the only question m asking is why init preloader not working you can see in the log and in the 1st post preloader support this eMMC but init preloader throws an error Not compatible! why is that! thanks |
08-13-2022, 21:56 | #7 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Last one is v2.34 https://infinity-box.com/news/?r=4237 |
08-14-2022, 05:44 | #8 (permalink) | |
Member: 2573102 Status: Offline Thanks Meter: 21 | Dear sir! Quote:
There is no Read/Write test in mt2 module That’s why I’ve used Mtk-v1.58 module It’s Mt6572 cpu And i always use MTk v1.58 to for older pllatform! Unless i need to use mt2! | |
08-14-2022, 18:13 | #9 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | > the only question m asking is why init preloader not working No idea what frmware was flashed to your phone and what was result. Also can not imagine what wass the problem with your phone before flash. You must try different firmware files and of you flashed it first youe flashtool it's always good idea to post fiull info about firmware that was in phone before flash, what was the issue etc. |
08-15-2022, 19:49 | #10 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: John Kemeny1926-1992 Age: 57
Member: 136220 Status: Offline Thanks Meter: 403 | Quote:
OLD TYPE [MediaTek] MT6572_S00 SP-Flash-Tool-v3.1344 Works with this type | |
The Following User Says Thank You to allttar For This Useful Post: |
