11-06-2021, 17:25 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: BEST COUNTRY
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 239 | Yes but its aske change boot.My dongke suporet hase overed but I think in new version its will show the same log. Its note aske code, only show netwark lock.if you need I can contact You by PC and by team you can take needed files fir support this phone.In market no box fore this phone, You can be 1st. |
11-06-2021, 17:59 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | If it's new phone you should use CM2MT2 What is the problem with CM2MT2? You can use it even after your support is expired. Just install not latest but prevous version and you can use it unlimited, 100 years after your support is expired. |
11-06-2021, 18:19 | #7 (permalink) |
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 239 | Please check dear Card found : , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.02 Load IDBase v11861 Ok! Operation : SP Unlock [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM9) MODE : BOOTROM PORT : 9 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT0000 , SBID : 0x0000 , HWVR : 0x0000 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : Wiko : SEC_6739 | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Selected AGENT doesn't have required configuration! Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! |
11-06-2021, 18:22 | #8 (permalink) |
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 239 | Operation : Memory Tool Init [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM9) MODE : BOOTROM PORT : 9 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E1 BROM : SecMode : SBC+SEL BROM : BOOTROM MODE : Wiko : SEC_6739 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 EMI : CNT : 0003 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERR : 0xC0070004 ERR : DA_HASH_MISMATCH Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
