unlocking gfone 301 and 411(aircel) i want to know that gfone 301 and 411 is supported for unlock . today i unlocked one 301 and one 411 so i read the code in mmodule 3.97(latest version) the code was same for both phones 19183512 it worked too but there are two problems one is when i restart the phone it ask the code everytime , 2nd problem is that whichever sim you put in sim 1 slot phone will display "aircel" (these phones have only one sim locked to aircel having the 2 sim slot ) i want to know that 19183512 is universal temprary unlock code for gfone aircel? as i have to unlock these phones in large quantity another problem is when i tried to read the flash file backup for both the phones g301 readed successfuly while 411 failed to do so (it was successfuly readed with dragon thow ) sorry about posting the logs as gsmhosting server was down so i failed to do so because logs are in diffrent pc |
there are logs 301 ==== [7/21/2011 3:25:59 PM] ==== COM20 [VCP0] selected module v3.97 Action: read unlock codes unlock method: read codes Model: Aircel-G301 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:BD39:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... warning: wrong packet cs Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: L132_JY01_F32_TXD_AIRCEL_Y97_T02_V02 Version: LENTEK23D_GEMINI_ULC_07B_HW 67 byte(s) read imei: 91************** connection Ok 178 byte(s) read 166 byte(s) read Phone lock: Off Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 1122 166 byte(s) read reading data... 972 byte(s) read lock[1] code: + 19183512 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 11 sec Remove/Install battery now ! |
411 ==== [7/21/2011 4:26:31 PM] ==== COM65 [Serial2] selected module v3.97 Action: read unlock codes unlock method: read codes Model: G-Fone-411-Aircel Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:70E8:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... warning: wrong packet cs Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: L98_AIRCEL_V8_0_6 Version: L90_HW 80 byte(s) read imei: 91******************** connection Ok 185 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1122 173 byte(s) read reading data... 972 byte(s) read lock[1] code: + 19183512 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 13 sec Remove/Install battery now ! |
failed flashing "read flash operation " for 411 ==== [7/21/2011 3:59:05 PM] ==== COM65 [Serial2] selected module v3.97 Device: G-Fone-411-Aircel Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:70E8:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... warning: wrong cs at 0x00001754, retry... warning: wrong cs at 0x00001754, retry... warning: wrong cs at 0x00001754, retry... warning: wrong cs at 0x00001754, retry... warning: wrong cs at 0x00001754, retry... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: L98AIRCEL_PCB01_GPRS_MT6223P_S00.L98_AIRCEL_V8_0_6 .BIN project-id: L98_AIRCEL_V8_0_6, 00000000 code offset: 00000000 ffs offset/size [01]: 00D00000/00300000 rom info structure: [standard] type (05) TCL-ID is absent ffs/eeprom address assigned: 00D00000 operation aborted Finished, time used: 19 sec Remove/Install battery now ! ==== [7/21/2011 4:00:53 PM] ==== COM65 [Serial2] selected module v3.97 Device: G-Fone-411-Aircel Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:70E8:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... warning: wrong cs at 0x00000B54, retry... warning: wrong cs at 0x00000B54, retry... read error recovered warning: wrong cs at 0x00002B54, retry... warning: wrong cs at 0x00002B54, retry... warning: wrong cs at 0x00002B54, retry... warning: wrong cs at 0x00002B54, retry... warning: wrong cs at 0x00002B54, retry... warning: wrong cs at 0x00002B54, retry... warning: wrong cs at 0x00002B54, retry... warning: wrong cs at 0x00002B54, retry... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: L98AIRCEL_PCB01_GPRS_MT6223P_S00.L98_AIRCEL_V8_0_6 .BIN project-id: L98_AIRCEL_V8_0_6, 00000000 code offset: 00000000 ffs offset/size [01]: 00D00000/00300000 rom info structure: [standard] type (05) TCL-ID is absent ffs/eeprom address assigned: 00D00000 operation aborted Finished, time used: 25 sec Remove/Install battery now ! ==== [7/21/2011 4:01:34 PM] ==== COM65 [Serial2] selected module v3.97 Device: G-Fone-411-Aircel Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:70E8:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... warning: wrong cs at 0x00001B54, retry... warning: wrong cs at 0x00001B54, retry... warning: wrong cs at 0x00001B54, retry... warning: wrong cs at 0x00001B54, retry... warning: wrong cs at 0x00001B54, retry... warning: wrong cs at 0x00001B54, retry... warning: wrong cs at 0x00001B54, retry... warning: wrong cs at 0x00001B54, retry... warning: wrong cs at 0x00001B54, retry... error: too many retries during read operation search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: L98AIRCEL_PCB01_GPRS_MT6223P_S00.L98_AIRCEL_V8_0_6 .BIN project-id: L98_AIRCEL_V8_0_6, 00000000 code offset: 00000000 ffs offset/size [01]: 00D00000/00300000 rom info structure: [standard] type (05) TCL-ID is absent ffs/eeprom address assigned: 00D00000 operation aborted Finished, time used: 23 sec Remove/Install battery now ! ==== [7/21/2011 4:02:02 PM] ==== COM65 [Serial2] selected module v3.97 Device: G-Fone-411-Aircel Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:70E8:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... warning: wrong cs at 0x00000354, retry... warning: wrong cs at 0x00000354, retry... warning: wrong cs at 0x00000354, retry... warning: wrong cs at 0x00000354, retry... warning: wrong cs at 0x00000354, retry... warning: wrong cs at 0x00000354, retry... warning: wrong cs at 0x00000354, retry... warning: wrong cs at 0x00000354, retry... warning: wrong cs at 0x00000354, retry... error: unexpected data: 1FC4CBDA32CB3B3A3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B 3A3B3B3B3B3E3B3BBB3BBAFBC7C4C3C4C4C4C7C4C4C4C4C6C6 C7C6C3C6C7C3C7C7C3C3C7C3EBD3DFEBFBFBFB3B3B3B3B3B3B 3B3B3B3B3B3B3B3B3B3B3B3B393BBB3B3ABBD3C4C4C5C5C7C6 C5C5C7C6C2C6C6C2C6D3C3CFC7C3C7C3DBDB3A3B3A3B3B3B3B 3B3B3A3B3B3A3A3C313E1393DBCEC4C4C4C4C4C4C6C4C6C6C7 C6C7C2C6C6C3C6C3C3C2CBFBEB9BBBBB3B383A3B3B3B3B3B3B 3B3B3B3B3B3B3B383ABB3B3BD3FBC2C5C4C4C4C6C4C4C6C7C7 C6C3C7C6C3C3E3DBD3DBFBD3FBBB3B3B3B3B3B3B3B3B3B3B3B 3B3BBB3B3B383CC1F3C6CBC3C4C4C6C4C4C6C4C3C6C2C7C7C2 C3C7C3C3C1 error: too many retries during read operation search rom info finished searching rom info... error: wrong answer: BB . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00D00000/00300000 sec info (detailed) detection... searching sec info#1... error: wrong answer: 3B . search sec info#1 finished error: wrong answer: FA error: connection lost Finished, time used: 26 sec Remove/Install battery now ! ==== [7/21/2011 4:09:07 PM] ==== COM65 [Serial2] selected module v3.97 Device: G-Fone-411-Aircel Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 23 sec Remove/Install battery now ! ==== [7/21/2011 4:15:09 PM] ==== COM65 [Serial2] selected module v3.97 Device: G-Fone-411-Aircel Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:70E8:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... warning: wrong cs at 0x00001B54, retry... warning: wrong cs at 0x00001B54, retry... warning: wrong cs at 0x00001B54, retry... warning: wrong cs at 0x00001B54, retry... warning: wrong cs at 0x00001B54, retry... warning: wrong cs at 0x00001B54, retry... warning: wrong cs at 0x00001B54, retry... warning: wrong cs at 0x00001B54, retry... warning: wrong cs at 0x00001B54, retry... ==== c:\InfinityBox\MModule\MModule.exe [7/21/2011 4:15:55 PM] ==== Infinity-Box - About |
any permanent unlock solution ??? |
please let me confirm permanent unlock is available? |
read 311 gfone error COM65 [Serial2] selected module v3.97 Device: G-Fone-311-Aircel Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:1C8D:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... warning: wrong cs at 0x00002754, retry... warning: wrong cs at 0x00002754, retry... warning: wrong cs at 0x00002754, retry... warning: wrong cs at 0x00002754, retry... warning: wrong cs at 0x00002754, retry... warning: wrong cs at 0x00002754, retry... warning: wrong cs at 0x00002754, retry... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent error: wrong answer: 91 error: can't read startup code area #1 rom info detection finished rom info ver: 04 sw version: XG01_GSM_K103_INDIA_128_PCB01_GSM_MT6223P_S00.V1_0 0_01_M100106EN0-I02.BIN project-id: V1.00.01_M100106EN0-I02, 23DEAA2C code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent ffs/eeprom address assigned: 00E00000 operation aborted Finished, time used: 20 sec Remove/Install battery now ! |
where is support ? Why there are problems in reading flash files |
311 flashing read error COM65 [Serial2] selected module v3.97 Device: G-Fone-311-Aircel Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:1C8D:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... warning: wrong cs at 0x0000A754, retry... warning: wrong cs at 0x0000A754, retry... warning: wrong cs at 0x0000A754, retry... warning: wrong cs at 0x0000A754, retry... warning: wrong cs at 0x0000A754, retry... warning: wrong cs at 0x0000A754, retry... read error recovered warning: wrong cs at 0x0000BF54, retry... warning: wrong cs at 0x0000BF54, retry... warning: wrong cs at 0x0000BF54, retry... warning: wrong cs at 0x0000BF54, retry... warning: wrong cs at 0x0000BF54, retry... warning: wrong cs at 0x0000BF54, retry... warning: wrong cs at 0x0000BF54, retry... warning: wrong cs at 0x0000BF54, retry... warning: wrong cs at 0x0000BF54, retry... error: too many retries during read operation search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent error: wrong answer: D7 error: can't read startup code area #1 rom info detection finished rom info ver: 04 sw version: XG01_GSM_K103_INDIA_128_PCB01_GSM_MT6223P_S00.V1_0 0_01_M100106EN0-I02.BIN project-id: V1.00.01_M100106EN0-I02, 23DEAA2C code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... error: wrong answer: 00 . search sec info#1 finished error: wrong answer: 00 error: connection lost Finished, time used: 35 sec Remove/Install battery now ! |
temporary unlock works gfone 311 too COM65 [Serial2] selected module v3.97 Action: read unlock codes unlock method: read codes Model: G-Fone-311-Aircel Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:1C8D:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: V1.00.01_M100106EN0-I02 Version: BIRD23C_GEMINI_08A_HW 80 byte(s) read imei: 9****************** connection Ok 186 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1122 174 byte(s) read reading data... 972 byte(s) read lock[1] code: + 90750051 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 11 sec Remove/Install battery now ! |
Are you sure that 311 model unlocked temporary but not permanently ? |
COM3 [VCP1] selected module v4.01 Device: G-Fone-411-Aircel Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup disabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:4FEA:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: L98AIRCEL_PCB01_GPRS_MT6223P_S00.L98_AIRCEL_V8_0_5 .BIN project-id: L98_AIRCEL_V8_0_5, 00000000 code offset: 00000000 ffs offset/size [01]: 00D00000/00300000 rom info structure: [standard] type (05) TCL-ID is absent ffs/eeprom address assigned: 00D00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 2088C4FFFF0043:2088C400000000 Backup required data Done ====> Patch required data ... ............................................... lock area found ............................................... lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... .................................................. .............. error: area 1 can not apply patch Special operation Done ====> Write ... flash: 2088C4FFFF0043:2088C400000000 flash: 2088C4FFFF0043:2088C400000000 Write: lock-area-1 flash: 2088C4FFFF0043:2088C400000000 flash: 2088C4FFFF0043:2088C400000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done Finished, time used: 2 min 17 sec Remove/Install battery now ! |
