04-10-2009, 13:39 | #1 (permalink) |
Insane Poster Join Date: Mar 2003 Age: 50
Member: 25320 Status: Offline Thanks Meter: 11 | Privileg X6 slave IMEI can't change master imei change ok but slave imei is original i do every option mode-1 mode-2 mode-3 for #2 imei but nothig imei is not change any ideas be welcom here i log MODE-1 Action: imei Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6219B, E0 Hardware version: X66APDBT_MT26_05C_HW_PCB01 Software version: X66APDBT_Bul.MLCD.96 Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 350135032135162 imei write method: mode-1 imei write channel: imei #2 for dual sim/mono CPU new imei: 350448011234561 verification failed operation failed ! Finished, time used: 6 sec Power off phone now ! MODE-2 COM10 [VCP0] selected module v2.80 Action: imei imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 350448011234561 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6219:8B02:8B01]... CPU: MT6219 high speed boot On chip: 0031:AC24:78C5 status: FF detected CPU: MT6226MA Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6219B,E02 Date: 2005.04.12 Version: 1.0 Version: X66APDBT_Bul.MLCD.9655.V1.5 Version: X66APDBT_MT26_05C_HW_PCB01 detecting structure #2... done 60 byte(s) read imei: 35013503213516 connection Ok detecting structure #2... done 60 byte(s) read verification... verification done: 35044801123456 Finished, time used: 18 sec Remove/Install battery now ! MODE-3 COM10 [VCP0] selected module v2.80 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write method: mode-3 imei write channel: imei #2 for dual sim/mono CPU new imei: 350448011234561 ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8B02:8B01]... CPU: MT6219 high speed boot On detected CPU: MT6226MA chip: 0031:AC24:78C5 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E223C2200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb detecting chip #01 in region #00... flash: 01227E223C2200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E223C2200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb detecting chip #01 in region #00... flash: 01227E223C2200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 02000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.80, database date: 28.03.2009): X70_PCB01_GPRS_MT6226M_S01.X66APDBT_BUL_MLCD_9655_ V1_5.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: X70_PCB01_GPRS_MT6226M_S01.X66APDBT_BUL_MLCD_9655_ V1_5.BIN ver. sw 2: X66APDBT_Bul.MLCD.9655.V1.5, 00000000 ffs offset/size: 01C00000/00400000 detecting security area (code #2)... .................................................. .................................................. .................................................. .................................................. .................................................. ...... security area (code #2) is absent detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 01C00000 flash: 01227E223C2200:29EA0000000000 checking area [00000000]: 00000000-01FFFFFF... ffs/eeprom found near: 01C00000 detecting ffs/eeprom size... ffs/eeprom size: 00400000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01C00000-01FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[X70_PCB01_GPRS_MT6226M_S01.X66APDBT_BUL_MLCD_9655_ V1_5.BIN]... file saved: D:\Program Files\InfinityBox\ChineseMiracle\eeprom[X70_PCB01_GPRS_MT6226M_S01.X66APDBT_BUL_MLCD_9655_ V1_5.BIN]_20090410-153242.B0E.bin flash: 01227E223C2200:29EA0000000000 Backup required data Done Patch required data ... 2 step(s) required Patch required data Done Special operation ... Special operation Done Write ... flash: 01227E223C2200:29EA0000000000 Write: eeprom Write Done Finalization ... Finalization Done Finished, time used: 248 sec Remove/Install battery now ! |
04-12-2009, 19:04 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | 1. Hm... Let me ask a question too: What is the reason to make posts regarding "Chinese" models in general forum if you can make it in special forum for "Chinese" models ? 2. did you tried to read text in software log window ? Code: ==================== New firmware detected (v.2.80, database date: 28.03.2009): X70_PCB01_GPRS_MT6226M_S01.X66APDBT_BUL_MLCD_9655_ V1_5.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== |
What LCD is usen in Privileg X6 | debeliamark | Chinese Models & Cloned Phones | 1 | 04-19-2010 10:09 |
cyclone box can't change to main mode [SOLVED - Thanks HRCO] | banalven1 | Cyclonebox | 5 | 03-29-2010 09:34 |
P200 Imei can't change Pls Help Elco | unitedtelecom | NSPRO | 0 | 09-06-2007 13:31 |
P200 Imei can't change Pls help! | unitedtelecom | UST Pro II | 0 | 09-06-2007 12:56 |
9210 imei can't change | Keke | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 04-16-2004 11:49 |
