04-04-2006, 16:04 | #1 (permalink) |
Junior Member Join Date: Dec 2005
Member: 205815 Status: Offline Thanks Meter: 1 | unlock motorora c139 with infinity box can anybody help me how to unlock C139 mobil, on my sceenshot i see no unlock sign for all mobil,itīs just for flash i think.is there any help! thanks in advance.bigj |
04-04-2006, 16:12 | #2 (permalink) |
Freak Poster Join Date: Feb 2003 Location: Craiova(Romania) or www.alfamo Age: 45
Member: 22553 Status: Offline Thanks Meter: 7 | Before go to settings and select phone type: C139, after that go and check in the " SERVICE" menu, there you have UNLOCK Function Regards! |
04-04-2006, 16:19 | #3 (permalink) |
No Life Poster Join Date: Oct 2005 Location: BISKRA Age: 55
Member: 192230 Status: Offline Thanks Meter: 106 | HI ................................. check documentation in the same folder \Moto01_v112 If you have problems with initial connection (software can't detect phone): 1. Open Device Manager 2. Open Ports COM & LPT 3. Right click on "Infinity USB Serial Port and select Properties 4. Select Tab Port Settings 5. Press to Advanced...button 6. Set Latency Timer value to 4 (see file Advanced_Port_Settings.jpg) |
04-04-2006, 16:25 | #4 (permalink) | |
Member: 205815 Status: Offline Thanks Meter: 1 | Thanks for your feedback, the probleme is that the dongle don't recognise the phone and I even don't have that model in the list only the C115 , C116 and V170 but the C139 is not listed, do I need to downlod its module seperatly or is the same serie.
04-04-2006, 16:35 | #5 (permalink) | |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | please read this http://forum.gsmhosting.com/vbb/show...highlight=C139 br <= The_Gorr => Quote:
04-04-2006, 17:03 | #6 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
Visit support area at www.infinity-box.com and downlaod latest Installation package v2.2 wih all latest software. | |
04-04-2006, 18:36 | #7 (permalink) |
Member: 205815 Status: Offline Thanks Meter: 1 | thanks all of u for the help, i installed the new software 2.2 v. but now if i press sp unlock, it tells me ress and hold power button. i did the command but it does not unlock.although i change the letenci speed to 4 and the all available com port.thanks in advance. |
04-04-2006, 18:44 | #8 (permalink) | |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | if all is ok with com port and also with speed check your cable br <= The_Gorr => Quote:
04-04-2006, 18:45 | #9 (permalink) | |
Member: 205815 Status: Offline Thanks Meter: 1 | In my Com and LPT I don't see any "Infinity USB Serial Port" I only have "USB serial Port" and set the latency speed to 4 as you said.
04-04-2006, 18:57 | #10 (permalink) | |
"USb serial port" is Ok too. check this: http://forum.gsmhosting.com/vbb/show...highlight=C139 Also, please, read instruction in yellow window (you will see it for sure when you start software). | |
04-04-2006, 21:59 | #11 (permalink) |
Member: 205815 Status: Offline Thanks Meter: 1 | Action: Unlock Device: C113,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... Err: boot[02]: Release Power button ! Connect Fail Failed ! Finished Remove/Install battery now ! Time used: 183 sec i will be very glad if someone can help me with this problem by unlock.thanks Last edited by Bigj; 04-04-2006 at 22:48. |
04-04-2006, 23:18 | #13 (permalink) | |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | man ! did you unlock any C113,C115,C116,C117,C118, using Infinity with your cable !! if not, please check your cable br <= The_Gorr => Quote:
Help me , I am unable to unlock BSNL G200CF with infinity-box? | gsm_surya | Infinity-Box | 4 | 01-06-2010 11:16 |
succsessfully unlocked nec n343i with infinity box | Harkishan singh | Infinity-Box | 4 | 10-27-2009 21:55 |
succsessfully unlocked motorola w377 with infinity box | Harkishan singh | Infinity-Box | 5 | 11-11-2008 08:12 |
Help me , I am unable to unlock BSNL G200CF with infinity-box? | gsm_surya | Infinity-Box | 3 | 04-11-2008 09:38 |
how to unlock Pana P341i with infinity box ? | dan0007 | Infinity-Box | 2 | 10-12-2005 08:54 |
