04-14-2011, 16:25 | #1 (permalink) |
Freak Poster Join Date: Jul 2003 Location: Lithuania,Kaunas Age: 48
Member: 33166 Status: Offline Thanks Meter: 4 | Need help repair Nokia N95-8GB RM-58 COM4 [VCP0] selected module v3.29 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash write: Firmware HX684_GEMINI_07B_HW.JX684_AR10_NT57_B2_V1_9ETEST--100419__n95_AR_16m_En_Ru_Gr_Fr_Es_De_Tr_Farsi_Pt_A r.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:6903:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent ==================== New firmware found (v.3.29, database date: 04.04.2011): HX684_GEMINI_07B_HW.JX684_AR10_NT57_B2_V1_9ETEST--100919.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 04 sw version: HX684_GEMINI_07B_HW.JX684_AR10_NT57_B2_V1_9ETEST--100919.BIN project-id: JX684_AR10_NT57_B2_V1.9ETEST, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 98004900000002:18E59F00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 177 min 29 sec Remove/Install battery now ! Maybe original flash file is newest, than in support. Maybe supporters can check backup. Thanks in advance Backup: https://rapidshare.com/files/4574004...175946.B0M.bin |
04-14-2011, 17:50 | #2 (permalink) |
Product Supporter Join Date: Nov 2010 Location: Every where
Member: 1549240 Status: Offline Thanks Meter: 1,130 | bro as i understand your flash file ver not match with original flash file ver so first of all need same set and read from full flash and write after post log and also need check lcd |
04-14-2011, 18:28 | #3 (permalink) |
Member: 33166 Status: Offline Thanks Meter: 4 | when I write readed fullflash, phone not power on. I can check then lcd. Log: COM4 [VCP0] selected module v3.29 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash write: Firmware HX684_GEMINI_07B_HW.JX684_AR10_NT57_B2_V1_9ETEST--100919__fullflash_20110409-175946.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:6903:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: HX684_GEMINI_07B_HW.XE684_CH3_NS5_B2_V1_9ETEST--090717.BIN project-id: XE684_CH3_NS5_B2_V1.9ETEST, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 98004900000002:18E59F00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 9 min 41 sec Remove/Install battery now ! |
04-14-2011, 20:36 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! try following: write Original backup HX684_GEMINI_07B_HW.JX684_AR10_NT57_B2_V1_9ETEST--100919 and next do format FFS compelte check if this will help |
04-15-2011, 11:14 | #7 (permalink) |
Member: 33166 Status: Offline Thanks Meter: 4 | Very good support, very good team, very fast answers. Thank you very much. After write full and ffs complete - phone working. I don't remember good, but before flash any flashfile I made FFS format complete, maybe only safe. Now I read good fullflash from working phone, maybe need: https://rapidshare.com/files/4575192...od_working.B0M |
The Following User Says Thank You to egidijus For This Useful Post: |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
