Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1261 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Jun 2009
Member: 1043909 Status: Online Thanks Meter: 56,546 | As ordinary, unique functions and methods released RDA8955x is an extra cheap SoC with 2G/GPS support. It is used in cheap wearable, IoT and feature phones. Supported CPU list: Spreadtrum: SC6530, SC6531, SC6531(A/C/D) SpreadTrum: SC68xx ( with external PAC ) SpreadTrum: SC770x ( with external PAC ) UniSoc: SC6531E, SC6533, SC6533G, SC770x RDA Mirco: RDA8955G, RDA8955GE, RDA8955L RDA Mirco: RDA8851 rev A,B,C,L,CL RDA Micro: RDA8826 Core NewChip: Support RDA 8955 Line (8955G, 8955GE, 8955L) BugFix: Support for some SC6533 revisions fixed ( Wrong PMT issue ) Support RDA 8955 Line (8955G, 8955GE, 8955L) - Identify ( Security info, compilation info, Hwinfo ) - Format FS / Reset Settings - Read UserCode / PrivacyCode - Repair Security - Read Flash / FW - Write Flash / FW / LOD Service Changed: CompileInfo extraction improved ( RDA / SPRD / UniSoc ) Changed: BOOTROM support improved ( RDA ) Changed: SVC ( Diag ) mode support optimized for modern UniSoc 89xx platforms UserData Changed: Security code read in FlashMode revised ( RDA ) Other BugFix: Lot of small different changes and fixes Option: GUI ( File -> GUI ) : allow select other interface mode !* Default - standard V2 line GUI !* Wide - best for big screen / big distance to monitor !* Wide Log - extend log window to screen size. Optimal for most cases https://www.infinity-box.com/support/?r=100137 |
The Following 4 Users Say Thank You to YellowBoss For This Useful Post: |
![]() | #1262 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: May 2005
Member: 148515 Status: Offline Thanks Meter: 17,748 | Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.10 - New year means new features ! As ordinary, unique functions and methods released Core Changed : FlashCore protocol updated NewSOC: UniSOC Tiger T61x series support NewSOC: UniSOC UIS7862 (Car HeadUnits SoC) series support NewSOC: SC7731E Android 10 / FastProto supported NewSOC: SC9832E Android 10 / FastProto supported Flasher Changed : Protocol updated Changed : NVM manager updated Changed : FastFlash protocol updated ( SC7731E, SC9832E supported ) Firmware reader Changed : Android 10 specific changes Changed : Initial Tiger and NaT devices support Changed : UltraRead protocol updated ( SC7731E, SC9832E supported under 0S loaders now ) Service NewFeature: Security Repair allow change PSN1/PSN2 - In newer devices PSN1/2 damage may lead to bootlop, ota and other issues - In newer devices PSN1/2 used as bootloader token Changed : Identify : Correct MEMORY and RAM size reading for Android 10 devices Changed : Identify : Read PSN1 and PSN1 Changed : Identify : SC9832E and SC7731E can be used to verify eMMC ReadOnly state (0S loader mode) Changed : Repair : Identify signed devices during repair Changed : NVM : Read and Write operations revised UserData Changed : UserData dump feature updated ( Legacy line fixes ) SPUnlock Changed : SC9863 support updated Changed : SC9832 support updated Changed : PermLock fix ( processed in automatic mode, fix issue with possible PermLock after first unlock try ) NewFeature: Error codes explanation and hints NewFeature: Damaged devices ( security destroyed ) detection NewFeature: Damaged devices ( permLock ) detection Model DB Changed : New generic loaders included for SC7731E with Android 10 ( 0S type ) Changed : New generic loaders included for SC7792E with Android 10 ( 0S type ) Changed : New generic loaders included for Tiger T61x Changed : New generic loaders included for UIS7862 Changed : ZTE, Itel and others line loaders updated to support faster operatons amd more HW variants Other Changed : GUI settings now stored and load select style, settings and other at next run Changed : Lot of different changes and fixes https://www.infinity-box.com/support/?r=100138 |
![]() | #1263 (permalink) |
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post: |
![]() | #1264 (permalink) |
Member: 1043909 Status: Online Thanks Meter: 56,546 | Infinity Data Explorer v1.11 - MTK, SPD updated and more improvements Data extraction based on full reconstruction of file system - MTK module updated - added Call List extraction for some models - SPD firmware structure detection improved, important algos and methods updated - Minor bugs fixed https://forum.gsmhosting.com/vbb/f29...tware-2733086/ |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
![]() | #1265 (permalink) |
Member: 1043909 Status: Online Thanks Meter: 56,546 | Infinity Chinese Miracle-2 MTK/MediaTek v2.17 - Standalone MT67xx auth ON Core Changed : Protocol updated ( Raphael/Legacy ) NewFeature: Standalone SLA/Auth [Raphael] ** Changed : Internal EMI engine updated : RAPAHEL : UFS support rebuild Flasher Changed: Core updated for RAPHAEL line Changed: UltraFlash feature updated, new security workarounds supported Service Changed: Identify !* Read new Android 10 specific fields, vendor-specific fields Changed: Smart Reset !* Optimized support for different customized and generic cases Changed: HW Report ( RAPHAEL - only ) !* UFS line devices now supported with following features: - CID info ( FlashIC base info, name, vendor ) - default info, even if boot can nott be completed by some HW or SW reasons - LifeInfo ( SLC, MLC, EOL status and use counters ) - allow understand how bad it feels - RPMB info ( is it key programmed or clean and can be re-used ) - Partitioning details and other - HWreport log saving enabled ( for further analyze ) !* Feature also allow automatic select and store for further use BOOTROM connection settings for RAPHAEL devices ( DRAM init ) !* HWreport not require complete boot in case of semi-dead devices. Useful for HWdebug !* HWreport result may vary in diffirent models and agents even on the same SoC ! Firmware Reader Changed : Some modern brand-specific changes ( Xiaomi, Oppo, Vivo, Realme ) Changed : New types supported Other BugFix : Many different minor changes and fixes Changed : Generic protocol rebuild Info !** - Standalone SLA/Auth allow you ignore device security setting and allow boot it without having any DA/Auth/Remote auth support - You can boot ( with supported SoC ) device with any generic da and perform any need operations - Support MT6765 - All security versions, no auth need, no special da need, no remote service need Support Xiaomi, Oppo, Vivo, Realme, Huawei and whatever else existing - Support MT6785 - All security versions, no auth need, no special da need, no remote service need Support Xiaomi, Oppo, Vivo, Realme, Huawei and whatever else existing NOTE 1: special boot-helper tool should be installed - included in CM2MT2 package NOTE 2: x64 OS should be used https://www.infinity-box.com/support/?r=100139 |
![]() | #1266 (permalink) |
![]() | #1267 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 17,748 | Infinity Chinese Miracle-2 MTK/MediaTek v2.18 - Standalone MTK auth ON - new models and features As ordinary, unique functions and methods released Core Changed: Protocol updated ( Raphael/Legacy ) Changed: Loader v2044 supported and tested ( v2028 was unstable with MT6765 ) NewChip: MediaTek AC8227 (Car HeadUnits SoC) supported NewChip: MediaTek AC8257 (Car HeadUnits SoC) supported Flasher Changed: Core updated for RAPHAEL line Service Changed: META core updated Changed: HW Report ( RAPHAEL - only ) - LifeStatus identify revised, in some cases it may shown wrong info. Strongly recommend use latest version for HWcheck ! !* Feature also allow automatic select and store for further use BOOTROM connection settings for RAPHAEL devices (DRAM init) !* HWreport not require complete boot in case of semi-dead devices, it is useful for HWdebug !* HWreport result may vary in diffirent models and agents even on the same SoC ! Firmware Reader Changed: Some modern brand-specific changes (Oppo, Realme) Changed: New types supported Changed: Internal Database updated Model DB Changed: New agents included for Tecno, Infinix ( with different SoC lines ) Changed: New DA base v2044 included Other Changed: GUI settings now stored and load select style, settings and other at next run Changed: Environment compatibility issue with 32 bit OS has been fixed Changed: Many different changes and fixes https://www.infinity-box.com/support/?r=100141 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by InfinityHelp; 01-28-2021 at 01:24. |
The Following 3 Users Say Thank You to InfinityHelp For This Useful Post: |
![]() | #1268 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 17,748 | Infinity Chinese Miracle-2 MTK/MediaTek v2.19 - Standalone MTK auth ON - NEW CPU As ordinary, unique functions and methods released Core: Changed: Protocol updated ( Raphael/Legacy ) AUTH: MT6580 with any security configuration supported standalone ! AUTH: MT6735 with any security configuration supported standalone ! AUTH: MT6737 with any security configuration supported standalone ! AUTH: MT6731 with any security configuration supported standalone ! AUTH: MT6739 with any security configuration supported standalone ! AUTH: MT6750 with any security configuration supported standalone ! AUTH: MT6755 with any security configuration supported standalone ! AUTH: MT6757 with any security configuration supported standalone ! AUTH: MT6761 with any security configuration supported standalone ! AUTH: MT6762 with any security configuration supported standalone ! AUTH: MT6763 with any security configuration supported standalone ! AUTH: MT6765 with any security configuration supported standalone ! AUTH: MT6771 with any security configuration supported standalone ! AUTH: MT6785 with any security configuration supported standalone ! AUTH: MT6795 with any security configuration supported standalone ! AUTH: MT6797 with any security configuration supported standalone ! AUTH: MT8163 with any security configuration supported standalone ! Changed: BootHelper package updated - Automatic Self-Learning function activated - Do not need to make HWreport anymore before other operations in most cases ! Service: Changed: META core updated Changed: Security repair features rebuild. Bugfixes. Firmware Reader: Changed: Some modern brand-specific changes (Vivo, Meizu) Changed: New types supported Changed: Internal Database updated Other: Changed: Many different changes and fixes Info: Alternative MTK drivers package uploaded to support are, intstall it if you have any kind of connectivity issues https://www.infinity-box.com/support/?r=100142 |
![]() | #1269 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 17,748 | Infinity Chinese Miracle-2 MTK/MediaTek v2.20 - Standalone MTK auth ON - NEW CPU As ordinary, unique functions and methods released Core: Changed: Protocol updated ( Raphael/Legacy ) AUTH: MT6752 with any security configuration supported standalone ! AUTH: MT6753 with any security configuration supported standalone ! AUTH: MT6768 with any security configuration supported standalone ! AUTH: MT6757 support improved/fixed Service: Changed: Identify procedure revised - Support modern Android 10 devices - Support for Android 11 devices activated Changed: SmartReset procedure - Support modern Android 10 devices - Support for Android 11 devices activated Firmware Reader: Changed: Android 10 specific changes for modern devices Changed: Android 11 initial support Changed: New types supported Changed: Internal Database updated ModelDB: Changed: Some specific and brand list update Other: Changed: Many different changes and fixes https://www.infinity-box.com/support/?r=100143 |
![]() | #1270 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 17,748 | Infinity Chinese Miracle-2 MTK/MediaTek v2.21 - MT67xx and MT81xx ON ! As ordinary, unique functions and methods released With this update we finishing following achievements: Complete MT67xx line support ! Complete MT81xx line support ! Core: Changed: Protocol updated ( Raphael/Legacy ) AUTH: MT6779 with any security configuration supported standalone ! AUTH: MT6799 with any security configuration supported standalone ! AUTH: MT8127 with any security configuration supported standalone ! AUTH: MT8167 with any security configuration supported standalone ! AUTH: MT8172 with any security configuration supported standalone ! AUTH: MT8173 with any security configuration supported standalone ! Changed: BootHelper updated - Automatic Self-Learning function improved Changed: EMI manager updated, most modern devices support has been included Flasher: Changed: Core updated for RAPHAEL line Firmware Reader: Changed: New types supported Changed: Internal Database updated ModelDB: Changed: Some specific and brand list update Other: Changed: Different changes and fixes Installer:[*] Installer become more compact and now contain two parts: required and optional[*] Optional Installer CM2MT2-boot-pack contain optional (legacy) boot files https://www.infinity-box.com/support/?r=100144 |
![]() | #1271 (permalink) |
![]() | #1272 (permalink) |
Member: 1043909 Status: Online Thanks Meter: 56,546 | Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.11 - Unlock, Repair, New CPU As ordinary, unique functions and methods released Core Changed: FlashCore protocol updated NewSOC: UMS9117 support ( service mode ) Flasher Changed: Protocol updated Changed: NVM manager updated Firmware reader Changed: Android 10 specific changes Changed: UltraRead protocol updated Changed: New types supported Service Changed: Repair : Security Repair allow now repair signed devices - Permanent lock and other issues can be also fixed with that feature - Repair can be done in Flash and Diag mode - Repair support new security devices as well ( Android 10 + ) Changed: Repair : UMS9117 repair security support activated ( Nokia line supported included ) Changed: Identify : Enabled Read All Info by default under FlashMode Changed: FormatFS : UMS9117 Reset/Format FS support activated SPUnlock Changed: UMS9117 support activated ( Nokia line supported included ) Changed: SC9863, SC9832 support improved Other Changed: Many internal changes and fixes Drivers: UMS9117 drivers are at support area https://www.infinity-box.com/support/?r=100145 |
@-:=:-:=:-:=:-:=warning for UST-PRO2 TEAM -:=:-:=:-=:[email protected] | nejm | UST Pro II | 5 | 01-26-2010 09:30 |
30-04-2009 : Infinity Box Update : SAMSUNG CDMA Models Supported | Infinity-Box | Service Products News & Updates | 0 | 04-30-2009 14:46 |
..: Ultimate Unlockers - UPDATES & NEWS - Latest version: 3.07 :.. | Mizar | Cruiser Suite | 4 | 12-11-2008 12:01 |
Update 31 May : NEC E101 Chinese flash files : ST55 Flash files uploaded : | Infinity-Box | Infinity-Box | 2 | 07-26-2008 09:55 |
