09-20-2022, 14:39 | #1321 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Loaders updated & structure improved [+] MT6771 experimantal loader [0_base] Every new boot-pack release has all previous boot-packs included, it means you should only install latest one to get all loaders https://infinity-box.com/news/?r=4270 |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
10-04-2022, 15:00 | #1322 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Infinity Chinese Miracle-2 #CM2MT2 v2.36 - general improvements and fixes - SmartInfo parser output revised - NVRAM parser output revised - Firmware remote verification enabled - Device remote verification enabled - Preloader parser revised and fixed - Peloader remote verification enabled - "KG State" moved to Service page - "Help" menu - View log files by right mouse click on message window - View log files via "File" menu - "Logs" button at main window to view log files - "Snap" button at main window to make screenshot - "Stop" button at main window - Verification for preloader|da|firmware integrity - Show current settings at operation start - Show "Local SLA" state at operation start - Show "Flash Write" settings at operation start - "HW Report" mode selection changed - "Check Account" button at "Settings" page to verify Username and Password validity - Loaders remote verification enabled - Show loaders information at boot time - Memory chip life-state warnings updated - "Stop" item removed from the top menu - Boot stage loader files information revised - "GUI Mode" item removed from the top menu and moved to "View" button - "Memory Tool" moved to "Service" page - "Make Service Report" moved to "Service" page - "Settings" -> "Firefy : EMI" menu item moved to "FireFly : AutoEMI" at "Settings" page - "GUI mode" save/restore on startup - "Change GUI mode" via "Settings" menu - HW Compatibility Wizard enabled - Server Hints engine enabled - "PMT Info" option at "Platform" page display Partition Info during "Identify" - "Save Boot Config" option at "Platform" page to store detected model config to models list - Required Dongle firmware version: 0153 https://infinity-box.com/news/?r=4271 |
10-04-2022, 15:00 | #1323 (permalink) |
10-10-2022, 14:21 | #1324 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity Chinese Miracle-2 #CM2MT2 v2.37 - general improvements and fixes - "Restore Backup" config mode updated - "Restore Backup" allow to select files manually - Flash file (Scatter) Open|Select|Clean buttons at "Flash" page - Flash file (Scatter) parser updated - Flash file (Scatter) selection issue fixes - MemoryTool file selection issue fixes - MemoryTool gui minor changes - "Switch to HS USB" option removed - Config storage engine updated - Account Check gives balance and subscription date - "PMT Info" config value stored - "Flash" page minor gui changes - Loaders remote verification revised - Installer updated to manage previously installed boot-pack - Required Dongle firmware version: 0153 https://infinity-box.com/?r=100206 |
12-05-2022, 11:22 | #1325 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity #CM2SP2 boot pack v1.15 released with updated loaders [+] ATouch [+] BQ [+] CallTouch [+] Dexp [+] Eager [+] iHunt [+] InnJoo [+] Invens [+] LiteTel [+] LYF-Jio [+] MyPhone [+] Realme [+] Samsung [+] Smart Download here https://infinity-box.com/?r=19&dir=/software |
12-08-2022, 02:56 | #1326 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Infinity Chinese Miracle-2 CM2MT2 v2.38 - general improvements and fixes !!! WARNING !!! Backup files storage structure changed, files and folders will be compressed. Software will convert files and folders at first run! If you have important data - make /backup/ folder copy for emergency case! Process may takes time, BE PATIENT! - Startup process revised - Backup files are packed, zip and 7z formats are supported (7z.dll is required) - Backup files default format is 7z - Backup|Restore partitions list updated - Backup overwrite request for "Identify" only, skip existing backup replacement for other operations - Partition size verification during backup - File content verification (zeroes) during backup creation - File content verification (zeroes) during backup restore - Display hw|sw info to log during backup file selection - Restore backup images with .bin and .img extensions - Legacy settings values removed - MemTool work path save|restore - MemTool window position save|restore - MemTool ui changes - Log window style customization - HW Report behaviour changed depends on selected Platform - Cloud: display hw|sw info about last connected device - Cloud: get previously stored backup file - Flash chip vendors list updated - ufs parser revised - emmc parser revised - emmc failure detection improved - nand parser revised - Firmware read/write last selected path save|restore - scatter file creation process rebuilded - scatter file load process revised - META mode connection method revised - META mode info and device version output revised - META mode memory leak fixed - Check free disk space on startup - Check free disk space on Flash Read - Flash Read file selection method updated - Flash Read process termination revised - Backup before Reset in META mode - Backup before Reset in Flash mode - extcsd backup file content verification - PMT (partition table) info output slightly changed - PMT (partition table) info included to device.txt during backup - Store device.txt with hardware and software info to backup - Store device.txt with hardware and software info to firmware - Store device.txt file as ini - Store loaders config to device.txt file - Verify backup presence before process - Error messages and software hints updated - More software hints for [Format] operations - More messages in log about process flow - [SMART RESET EXTRA] error handling revised to recover after error - Create Screenshot [Snap] as .png instead of .bmp (quite compact) - Device brand|model detection revised - Updates checker rebuilded - External update checker disabled - External firmware uploader enabled - [Stop] process revised - Customs Settings -> EMI button extract prevoader from partition image on load - MemTool selection mode for 128 Mb and 256 Mb in list - MemTool file selection revised - MemTool operations revised - [Flash] page minor ui changes - [Security] page minor ui changes - [NVRAM Read] operation revised - [NVRAM Write] operation revised - NVRAM backup file format changed - [Restore Backup] operation allow to select backup file - [Restore Backup] has new restore mode [+preloader] - Check free disk space before backup - settings.ini new value [where] backup=backup\ - settings.ini new value [where] boot=boot\ - settings.ini new value [where] tools=..\tools\ - settings.ini new value [where] firmware=firmware\ - SC engine revised - Files verification config option in [Settings] page - Files verification for nvram backup enabled - Memory management engine revised - [KG] moved to [Misc] section - Dialogs texts revised. Message text will be visible in log window on selection - Minor log text messages and ui changes - Check required dll's on startup - ssleay32.dll included to installer to improve compatibility - 7z.dll included to installer - /tools/iosFileUploader included to installer - Required Dongle firmware version: 0153 https://infinity-box.com/?r=100207 |
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post: |
12-25-2022, 18:53 | #1327 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity Chinese Miracle-2 #CM2MT2 v2.39 - MT6789 [Helio G99] and more Loaders updated: /boot/0_generic/MT6781_Generic [LUCI] /boot/0_generic/MT6789_Generic [LUCI] /boot/Infinix/Infinix-G99-General /boot/Infinix/Infinix-X676B /boot/Tecno/Tecno-G99-General General: New protocol supported: [LUCI] - MT6781, MT6789, MT6895, MT6983 etc. Supported: SecurityRepair : Generic lines support for latest phones in both FLASH and META mode FormatFS : SmartReset, SmartResetExtra - include reset settings, frp, privacy etc. FirmwareReading : Factory-like, complete, safe firmware, compatible with MT2 and SPFT too FirmwareFlashing : Correct, safe, factory and read firmware flashing support Service : Service operations supported : Identify, NVRAM operations, MemoryTool, HW Info etc. FormatFS: Smart Reset updated: New types supported Smart Reset updated: Android 11-12 specific changes Smart Reset updated: A/B devices specific changes Firmware reader: NEXTGEN [LUCI] phones line support Factory-like firmware reading now supported [LUCI] XML-scatter generation now supported [LUCI] Android 13 support activated [under test] Android 12 support improved Android 10-11 support rebuild AB devices support complete rebuild. All known formats supported. More accurate detection of vendor-specific partitions and handling Escape from OTA issues and other startup faults etc. on some phones Scatter creation for latest devices revised, more chip-depend versions now supported Firmware flasher: NEXTGEN phones line support [LUCI] Factory and Read firmware flashing now supported [LUCI] XML scatter, TXT scatter and flash.xml can be used as FlashFile input Service: Identify : Now read active system info if device belong to AB BootLoader: Unlock and Lock as separate buttons now BootLoader: Unlock in FireFly mode for LEGACY phones has been fixed BootLoader: Unlock in FireFly mode for some of RAPHAEL phones has been fixed MemoryTool: LUCI support, compatibility improvements The Rest: - Loaders storage structure updated [built-in] /boot/0_base/X_FireFly/ => /boot/XFireFly/base/ [boot-pack] /boot/0_base/MT6570_*/ => /boot/0_rare/MT6570_*/ [boot-pack] /boot/0_base/MT6771/ => /boot/Vivo/MT6771/ - Loaders package updated [built-in] /boot/0_base/base_v2216/ - Bases and Models list sort order revised - Firmware version parser revised - Error messages and usage hints updated - eMMC EOL status hints updated - Update checker revised https://infinity-box.com/?r=100210 |
12-25-2022, 18:53 | #1328 (permalink) |
The Following 3 Users Say Thank You to YellowBoss For This Useful Post: |
01-29-2023, 17:32 | #1329 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity #CM2SP2 Diag Helper tool v1.04 Use it in case of DIAG/SVC mode failure with latest SPD devices. Wipe, User Data and Security Code Reset: several types of devices handling improved Dongle is not required, just run and use for free https://infinity-box.com/?r=100209 |
01-29-2023, 18:32 | #1330 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity #CM2MT2 boot-pack v2.40 with updated loaders Loaders & structure updated [+] Condor [+] Dlight [+] Xiaomi/Redmi-9c/ linked to base-2112 + preloader file from /Redmi-9/ [+] Xiaomi/Redmi-9a/ updated with preloader file from /Redmi-9/ [+] legacy loaders moved to /0_rare/ [+] /0_base/v17xx/ moved to boot-pack [+] /0_base/v18xx/ moved to boot-pack [+] /0_base/v19xx/ moved to boot-pack [+] /0_base/v20xx/ moved to boot-pack CM2MT2 v2.39 and higher should be used with the next loaders: [+] Infinix/Infinix-G99-General/ [+] Infinix/Dimensity-9000/ [+] Infinix/X676B/ [+] Tecno/Tecno-G99-General/ [+] Tecno/Dimensity-9000/ [+] Tecno/Phantom-X2-X2Pro/ [+] /0_generic/ loaders for latest MT6781/MT6789/MT6983 are inside sw installer Every new boot-pack release has all previous boot-packs included, it means you should only install latest one to get all loaders https://infinity-box.com/?r=100188 |
02-01-2023, 00:03 | #1331 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity Chinese Miracle-2 #CM2MT2 v2.40 General: FireFly : Protocol updated FireFly : Activated new operations 1. Firmware Read 2. Firmware Write 3. MemoryTool : EXTCSD Read 4. MemoryTool : EXTCSD Write FormatFS: Smart Reset updated: New types supported Smart Reset updated: Android 13 specific changes Firmware reader: Firmware Read activated in FireFly mode Android 13 support improved [under test] Firmware flasher: Flasher Engine updated : [LUCI], [RAPH] and [LEGACY] protocols updated Firmware Flashing activated in FireFly mode Service: Identify : Now read active system info if device belong to AB BootLoader: Unlock/Lock revised in FireFly and MTK mode MemoryTool: New Operation : EXTCSD read - Allow read EXTCSD config from eMMC. Made default at boot also New Operation : EXTCSD write - Allow write EXTCSD config in eMMC Both operations supported only in FireFly mode for now! The Rest: Loaders updated Previous versions of loaders partially moved to CM2MT2 boot-pack CM2MT2 boot-pack v2.40 or newer should be installed to get latest loaders Log output management updated BugFixes and minor updates Required Dongle firmware version: 0154 https://infinity-box.com/?r=100218 |
02-01-2023, 00:03 | #1332 (permalink) |
02-09-2023, 13:58 | #1333 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | #CM2SP2 Diag Helper tool v1.05 Use it in case of DIAG/SVC mode failure with latest SPD devices and for Wipe, User Data and Security Code Reset [+] Connection protocol updated [+] Minor User Interface changes with Snap|Screenshot button and log files easy access Dongle is not required, just run and use for free Download here https://infinity-box.com/support/ |
03-26-2023, 15:50 | #1334 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Infinity Chinese Miracle-2 #CM2MT2 v2.41 General: - FireFly core loader updated: /XFireFly/base/FireFly_AllInOne_DA.bin - FireFly mode operations updated such as bootloader unlock etc. - Many internal changes Image management: - Preloader parser/converter updated - Preloader/EMI open dialog updated for bin/img files - DA, Cert, Auth, Preloader load/verification method updated User Interface: - log management engine updated - software messages revised Infinity Chinese Miracle-2 #CM2MT2 v2.42 General: - Maintenance release - Memory management improved - Many internal changes - Boot time flow process updated - Boot time error handling improved User Interface: - flash chip info output revised - software messages & hints updated |
03-26-2023, 15:50 | #1335 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | #CM2SP2 Diag Helper tool v1.07 [+] pac file analyzer updated - more info extracted from image Download here https://infinity-box.com/support/ |
@-:=:-:=:-:=:-:=warning for UST-PRO2 TEAM -:=:-:=:-=:-@ | nejm | UST Pro II | 5 | 01-26-2010 09:30 |
30-04-2009 : Infinity Box Update : SAMSUNG CDMA Models Supported | Infinity-Box | Service Products News & Updates | 0 | 04-30-2009 14:46 |
..: Ultimate Unlockers - UPDATES & NEWS - Latest version: 3.07 :.. | Mizar | Cruiser Suite | 4 | 12-11-2008 12:01 |
Update 31 May : NEC E101 Chinese flash files : ST55 Flash files uploaded : | Infinity-Box | Infinity-Box | 2 | 07-26-2008 09:55 |
