04-11-2008, 16:19 | #1 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 744651 Status: Offline Thanks Meter: 20 | Urgent Need Cable for MPEG4 P888i I just bought an Infinity Box and set of cables that were recommended for Chinese Phones. I bought these things specifically to repair a number of Chinese MPEG4 P888i handsets that I have that keeps switching on and off when the sim cards are placed in the phone. Sadly, I did not get a cable to fit this phone in the 60+ cables that i have. Can someone help me locate this cable, or is it possible, that I can take one of the data cables for the phone and add an RJ45 jack to it and work it that way? Last edited by DualSimCell; 04-11-2008 at 16:22. Reason: typo on header |
04-11-2008, 20:13 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! yes, start from opening phone and checking which MCU it is based. you had to buy our pinout finder, this would be bettter than 60 cables. but as long as you didnt- we will advice you how to make own cable. just need to find pinout. but i repeat- start from checking MCU type |
04-12-2008, 13:59 | #5 (permalink) | |
Member: 744651 Status: Offline Thanks Meter: 20 | Hi Infinity Help Quote:
Thanks for your quick response, as mentioned, i'm a complete rookie to this, but not technically challenged, can you give me a little guidance on how to go about cheking the MCU type? and pinout Thanks | |
04-12-2008, 16:10 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! just open phone, remove metal shield and check what is written on MCU. if this MCU is supported by infinity soft- i will advice how to find pinout |
04-17-2008, 22:18 | #10 (permalink) |
Member: 744651 Status: Offline Thanks Meter: 20 | Can I email you pictures of the phones?...please email me.. [email protected] |
04-22-2008, 01:09 | #13 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! email recieve, this is double MCU phone. poinout you can find by yourself if you measure voltage on all phone pins. Data lines will show 2,7-2,9 volts |
04-22-2008, 18:52 | #15 (permalink) |
No Life Poster Join Date: Jan 2005 Location: IN YOUR HEART
Member: 109163 Status: Offline Thanks Meter: 75 | software version: 1.07 cable type: 1x12 (L12C) platform: MT62xx (autodetect) searching adapter at COM17... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6226 result: Rx:10 Tx:6 time required: 56 sec reverse software version: 1.07 cable type: 1x12 (L12C) platform: MT6205, MT6217-MT6228 searching adapter at COM17... adapter found, version: 2000 pins: 12, reversed ! power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6226 result: Rx:3 Tx:7 time required: 16 sec |
!!! Urgent !!! Need Schematics For Unlocking Cable 4 Ericcson A2628 | colonic | Old Ericsson Phones & Sony Phones | 2 | 01-15-2004 12:03 |
urgently need flash for 8850 - for flasher 1 (through log) | aod@gsm | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-18-2002 05:15 |
urgently need C4_10_87 for V2288 | GSM Deals | Motorola Old Legacy (EMMI) | 3 | 01-22-2002 22:02 |
Urgent need dump for sagem 922 | sashpeto | Infineon C16X M51 & ARM7 M52 BASED | 0 | 08-05-2000 23:02 |
Please, I urgently needed soft for N3210 v 4.65 | MP | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-08-1999 10:29 |
