05-29-2009, 19:28 | #1 (permalink) |
Registered User Join Date: Aug 2004 Age: 54
Member: 76533 Status: Offline Thanks Meter: 8 | Urgent please cvp flash nokia e71 2x5 ==================== identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: TD.E11ATV.E11.F1.1.0.T04D090314.BIN ver. sw 2: TD.E11ATV.E11.F1.1.0.T04D090314, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... |
05-29-2009, 20:52 | #3 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 476420 Status: Offline Sonork: 100.1605239 Thanks Meter: 164 | bro i wellgive you easy method to flush all chaines phone.its same with u phone 1. If you don't know original/required firmware version: check phone PCB to find any reference to originl firmware version. 2. Many phones has different name but the same hardware, so main criteria to find correct flash file is firmware version but not phone model name. 3. Flash file name consist of the next parts: ================================================== ================================= file name: E550_A5FRENCHBT_E550_GPRS_MT6226_S01.01_1__Cect-T689_16m_En_Fr.B0M.bin "E550_A5FRENCHBT_E550_GPRS_MT6226_S01.01_1": firmware version (with CPU info) "Cect-T689": model name "16m": flash chip size: 4Mb, 8Mb, 16Mb, 32m, 64m "En_Fr": languages inside firmware (English, French) "B0M.bin": firmware file extension "B0E.bin": eeprom/ffs file extension ================================================== ================================= file name: CM_GPRS-K588_Y560_JGH_PCB01_GPRS_MT6227_S01_16m_En_Cn_w_ee prom.B0M.bin "CM": "ChineseMiracle" "GPRS-K588": model name "Y560_JGH_PCB01_GPRS_MT6227_S01": firmware version (with CPU info) "16m": flash chip size: 4Mb, 8Mb, 16Mb "En_Cn": languages inside firmware "w_eeprom": contain eeprom/ffs inside file, it's "full flash" "B0M.bin": firmware file extension "B0E.bin": eeprom/ffs file extension ================================================== =========================== |
The Following User Says Thank You to malpinssa For This Useful Post: |
05-30-2009, 13:56 | #4 (permalink) | |
Member: 76533 Status: Offline Thanks Meter: 8 | Quote:
Thanks for the reply, but Flash 6225 I hope you did not understand the explanation | |
05-30-2009, 14:16 | #5 (permalink) |
Member: 76533 Status: Offline Thanks Meter: 8 | Flash did not understand the kind of help I hope OM3 [VCP0] selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:2A03:0007 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 230400 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb Warning: probably flash chip is empty, erased, incorrectly flashed or damaged ! What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 98000300000001:FFFFFF00000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting ffs/eeprom structure pass 1... .................................................. ...... can't detect fat record name location error: ffs/eeprom detection failed: element #1 detecting ffs/eeprom structure pass 2... .................................................. ...... can't detect fat record name location error: ffs/eeprom detection failed element #2 Check firmware integrity Done Check firmware content ... detecting firmware version... .................................................. .............. .................................................. .............. done warning: can not detect firmware version if software not respond/freez: make "Find firmware version (slow process)" unchecked and repeat operation. detecting firmware build... .................................................. .............. .................................................. .............. done detecting product-id... .................................................. .............. done detecting languages... .................................................. .............. error: can't detect language parameter #1 warning: can not detect language names if software not respond/freez: make "Find language names (slow process)" unchecked and repeat operation. Check firmware content Done Backup required data ... Finished, time used: 220 sec Remove/Install battery now ! |
05-31-2009, 23:27 | #6 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
what problem did you have with your phone? | |
urgent please flash nokia e71 2x5 plz | bahsar333 | Infinity-Box | 7 | 07-22-2009 16:00 |
Can flash Nokia E71-2 RM-357 With MT-Box??? | svchost | MT-BOX | 2 | 02-27-2009 00:27 |
Urgent please help on nokia 2310 software ok but no power on with battery | mobilecitycbk | Nokia Hardware & Hardware Repair | 1 | 11-15-2007 13:09 |
[URGENT!!!]Where to flash Nokia 9290 ROM? | geniusb | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-16-2005 00:22 |
