09-08-2007, 19:23 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If you write to phone original backup it must be alive in any case. If after backup restore your phone is dead it can be 2 reasons: 1. empty battery 2. damaged phone hardware Please, check both. |
09-08-2007, 20:05 | #3 (permalink) |
No Life Poster Join Date: Aug 2004 Location: in my office Age: 48
Member: 78502 Status: Offline Sonork: 100.86270 Thanks Meter: 7 | MOBILE WORK BEFORE ONLY REST WITH SIM ONLY I FORMAT ALSO BATTER FULL CHARG I TRY ALSO COPY FLASH FROM ATHERE MOBILE SAME MODEL WRITE ALL OK SEE THIS LOG Device: Autodetect: 6205-6227, 6228 Checking data, wait... advanced flash detection active Action: write flash "smart write" active write: Firmware skip: Customization skip: Language Pack skip: Eeprom Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Check space... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detecting eeprom area in 1 chip(s)... flash: 01227E22202200:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom area Do you want to use standard eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard eeprom address selected by user detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area: 00000000:00E00000-00FFFFFF reading [eeprom]... file saved: backup_eeprom_20070909-083914.B0E.bin flash: 01227E22202200:29EA0000000000 Check space Done Manipulation... Manipulation Done Finalization... Finalization Done Write... detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation New firmware detected: TELSDA26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16 _MP_V3_F3.BIN - make "Read detailed information, ask/rpl" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) identification data Ok identification data backup saved: id.23F79E0B.[TELSDA26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16 _MP_V3_F3.BIN_349D5EAC].rpl identification detection finished Area: Firmware flash: 01227E22202200:29EA0000000000 Write: Firmware NOT FINSH STILL COPY |
LG300GB after Formate Dead. . . . . . | kashi4lucky | Infinity-Box | 2 | 06-21-2009 16:03 |
SL45 need help after format dead | jakoy | DreamBox | 1 | 03-05-2009 16:35 |
>>> N95 CM after format DEAD <<< | keaelite | Infinity-Box | 3 | 06-03-2008 09:21 |
ZTE e328 after format dead | ayaz ali | Infinity-Box | 3 | 04-29-2008 09:56 |
second phone after format dead | fata24 | SpiderMan | 7 | 03-12-2008 23:58 |
