01-10-2009, 08:17 | #2 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 528831 Status: Offline Thanks Meter: 18 | vadafone 225 flashing error COM5 [VCP0] selected Device: ZTE-225, Vodafone-225 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 00BF:7353 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_eeprom-sta_20090110-124231.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_eeprom-sec_20090110-124234.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_eeprom-complete_20090110-124241.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: Firmware Writing: Firmware repair write error [00401000:0800]... error: write failed[00400000] Write Failed Finished, Remove/Install battery now ! Time used: 37 sec |
01-21-2009, 21:48 | #6 (permalink) | |
Banned Join Date: Apr 2007
Member: 484733 Status: Offline Thanks Meter: 10 | Quote:
Here is Log: COM3 [VCP0] selected module v1.60 Device: Digibee-BSNL-G200CF Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00BF:7353 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware Write Done Finished, time used: 209 sec Remove/Install battery now ! Plese Help................. | |
01-22-2009, 06:07 | #8 (permalink) |
Member: 484733 Status: Offline Thanks Meter: 10 | Sir, I have got the phone dead.While writing flash it gives this error: repair write error [00401000:0800]... error: write failed[00400000] previous log is here COM5 [VCP0] selected Device: ZTE-225, Vodafone-225 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 00BF:7353 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_eeprom-sta_20090110-124231.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_eeprom-sec_20090110-124234.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_eeprom-complete_20090110-124241.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: Firmware Writing: Firmware repair write error [00401000:0800]... error: write failed[00400000] Write Failed Finished, Remove/Install battery now ! Time used: 37 sec |
01-22-2009, 15:48 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If your phone was dead you can try to flash it with repair eeprom file and then make unlock. If phone still dead you must check phone hardware !!! |
01-25-2009, 20:32 | #10 (permalink) | |
I m selecting BSNL-G200 because it is being not possible to write flash by selecting zte-225 or vodafone 225. But I m confusing in selecting flash files.There are no option to read detailed information or anything like this.There r a lot of files in support area.So please tell me how to select correct files.Or should I try with each files. Please help................. | |
01-25-2009, 21:01 | #12 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
really added on the support site.. 1_ZTE-225_Main_VDF-P108A2B06-Tu-TU02_g3dBV2.0_Jun-5-2007.B1M.bin 2_ZTE-225_LP_VDF-P108A2B06-Tu-TU02_g3dBV2.0_Jun-5-2007_Tr.B1P.bin . . . . . etc | |
01-27-2009, 07:01 | #14 (permalink) | |
01-27-2009, 13:10 | #15 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You can try to flash phone with any firmware + lp, f.e. use this files: 1_ZTE-225_Main_VDF-P108A2B06-Tu-TU02_g3dBV2.0_Jun-5-2007.B1M.bin 2_ZTE-225_LP_VDF-P108A2B06-Tu-TU02_g3dBV2.0_Jun-5-2007_Tr.B1P.bin |
Vadafone 803T unlock error. | h3911308 | FuriousGold | 2 | 09-16-2010 19:25 |
Vodafone 225 flash error | Riteshgpt60 | Infinity-Box | 5 | 01-16-2010 02:17 |
vadafone 225 flashing error recovered | rehmani | Infinity-Box | 1 | 08-29-2009 14:53 |
vodafone 225 flashing error | amit_varietymob | Infinity-Box | 4 | 04-10-2009 14:51 |
how to unlock vadafone 225 | senkron24 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 4 | 10-18-2008 13:30 |
