01-17-2018, 13:26 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Online Sonork: 100.1684818 Thanks Meter: 1,693 | vernee mix2 mtk6757cd frp the chip mtk6757cd suported? i try it with cm2 unknow boot i try it with ast frp fail i try on fastboot mode and fail 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! INFO : max-download-size: 0x8000000 INFO : partition-size:flashinfo: 1000000 INFO : partition-type:flashinfo: raw data INFO : partition-size:userdata: 32000000 INFO : partition-type:userdata: ext4 INFO : partition-size:cache: 1b000000 INFO : partition-type:cache: ext4 INFO : partition-size:system: f4800000 INFO : partition-type:system: ext4 INFO : partition-size:tee2: b00000 INFO : partition-type:tee2: raw data INFO : partition-size:tee1: 500000 INFO : partition-type:tee1: raw data INFO : partition-size:logo: 800000 INFO : partition-type:logo: raw data INFO : partition-size:boot: 1000000 INFO : partition-type:boot: raw data INFO : partition-size:lk2: 100000 INFO : partition-type:lk2: raw data INFO : partition-size:lk: 100000 INFO : partition-type:lk: raw data INFO : partition-size:nvram: 500000 INFO : partition-type:nvram: raw data INFO : partition-size:md3img: 500000 INFO : partition-type:md3img: raw data INFO : partition-size:md1arm7: 300000 INFO : partition-type:md1arm7: raw data INFO : partition-size:md1dsp: 400000 INFO : partition-type:md1dsp: raw data INFO : partition-size:md1img: 1800000 INFO : partition-type:md1img: raw data INFO : partition-sizeroinfo: 300000 INFO : partition-typeroinfo: raw data INFO : partition-size:sec1: 200000 INFO : partition-type:sec1: raw data INFO : partition-size:seccfg: 800000 INFO : partition-type:seccfg: raw data INFO : partition-sizerotect2: 978000 INFO : partition-typerotect2: ext4 INFO : partition-sizerotect1: 800000 INFO : partition-typerotect1: ext4 INFO : partition-size:metadata: 2000000 INFO : partition-type:metadata: raw data INFO : partition-size:nvdata: 2000000 INFO : partition-type:nvdata: ext4 INFO : partition-size:nvcfg: 800000 INFO : partition-type:nvcfg: ext4 INFO : partition-size:frp: 100000 INFO : partition-type:frp: raw data INFO : partition-size:expdb: 1400000 INFO : partition-type:expdb: raw data INFO : partition-sizeara: 80000 INFO : partition-typeara: raw data INFO : partition-size:recovery: 1800000 INFO : partition-type:recovery: raw data INFO : partition-size:boot_para: 100000 INFO : partition-type:boot_para: raw data INFO : partition-sizereloader: 40000 INFO : partition-typereloader: raw data INFO : off-mode-charge: 1 INFO : warranty: yes INFO : unlocked: no INFO : secure: yes INFO : kernel: lk INFO : product: HCT6757_66_N INFO : version-preloader: INFO : version: 0.5 INFO : Done!! OEM : FAILunknown command Done! Elapsed: 00:00:08 Operation : Reset FRP [ v1.03 ] Mode : Remove MTK GENERIC FRP Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! FRP Erase FAIL! Done! Elapsed: 00:00:09 and cm2 log Wait for phone... Phone found! [ 77 ] Sync... Inital Boot Ok! BB_CPU_PID : 0551 BB_CPU_NME : [MediaTek] MTxxx BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0001 Processing BROM stage Settings for BROM configured! SecCfgVal : 0xE1000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : Unknown Mode! Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! |
01-23-2018, 13:26 | #3 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, You can try to change DA from latest spft or firmware folder, select scat from firmware and try to remove frp. But try at your own risk since it's officially not supported. Br. Infinity Box Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
03-22-2018, 15:07 | #11 (permalink) |
Freak Poster Join Date: Jul 2008 Location: algeria
Member: 816596 Status: Offline Sonork: zinnou Thanks Meter: 14 | solution frp VERNEE MIX2 download agent DA_PL_CRYPTO20.bin manual format flash BEGIN ADDRESS 0x2d88000 FORMAT LENGTH 0x2e87e00 WITH Flashtool v.5.17.44 SP_Flash_Tool_v5.1744 AND FIRMWAR Version only for mix2 4gb t900e-nb-k600a-63m-fhd-512g32g-bom10-3m-n-Dis_MIX_2_20171215-sign_user Last edited by zinnou; 03-22-2018 at 15:15. |
The Following User Says Thank You to zinnou For This Useful Post: |
04-04-2018, 17:31 | #12 (permalink) | |
No Life Poster Join Date: Jun 2015 Location: the planet earth
Member: 2406539 Status: Offline Thanks Meter: 101 | Quote:
error: status sec write data not allowed (0xC002000C) | |
The Following User Says Thank You to TMAC1122 For This Useful Post: |
