08-23-2008, 15:12 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: MX-KEY is the BEST NOKIA TOOL Age: 52
Member: 59732 Status: Offline Thanks Meter: 47 | panasonio N75 dead COM31 [VCP2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:7E26:52EF high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.D6893D9C.[CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_08_26B_HL_L5 SM_207_070918_LD-TR0_OV0_SS75_CTF_BT.BIN_8DE6BA47].rpl identification#1 detection finished device-id: D6893D9C identification#1 protocol ver: 04 ver. sw1: CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_08_26B_HL_L5 SM_207_070918_LD-TR0_OV0_SS75_CTF_BT.BIN ver. sw2: LION6_08_26B_HL_L5SM_207_070918_LD-TR0_OV0_SS75_CTF_BT, B8451972 ffs offset/size: 00F00000/00100000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00F00000 flash: EC257E25082501:2CEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_08_26B_HL_L5 SM_207_070918_LD-TR0_OV0_SS75_CTF_BT.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_08_26B_HL_L5 SM_207_070918_LD-TR0_OV0_SS75_CTF_BT.BIN]_20080823-193733.B0E.bin flash: EC257E25082501:2CEA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:2CEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_D6893D 9C_CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_08_26B_HL _L5SM_207_070918_LD-TR0_OV0_SS75_CTF_BT.BIN_8DE6BA47_20080823-193756.B0X.bin Finished, time used: 377 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
N75 Dead Mt-box | codes4gold@hotm | MT-BOX | 0 | 07-18-2008 22:46 |
N75 Dead | milankumardoshi | BB5BOX | 0 | 04-24-2008 08:38 |
n75 dead | milankumardoshi | BB5BOX | 0 | 04-23-2008 12:49 |
help i flash n75 dead | tumudon | Nokia Base Band 5 ( BB-5 ) | 7 | 12-18-2007 04:51 |
help i flash n75 dead | tumudon | MT-BOX | 1 | 09-25-2007 19:02 |
