06-01-2009, 06:47 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: INDIA(GUJRAT,RAJKOT) Age: 37
Member: 397884 Status: Offline Sonork: 100.1587035 Thanks Meter: 168 | very strange problem in chinese mirecle when i read any phone read errer comes and in motorola modul i can't detect any phone(c140,c117, etc) i format my pc i change other pc but same problem i tride too much for solve this problem but nothing solution from my so plese sir give some solution for this problem and sya how i solve this problem here is log of errer COM7 [Serial2] selected module v2.81 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:3C03:000F status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: E868_X3_PCB01_GPRS_MT6225_S00.00_0.BIN ver. sw 2: E868_X3.00.0, 00000000 ffs offset/size: 00E00000/001FF000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E10000 Detected ffs/eeprom address is non-standard: 00E10000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00E10000 detecting ffs/eeprom size... ffs/eeprom size: 001F0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E10000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: E868_X3_PCB01_GPRS_MT6225_S00.00_0__fullflash... warning: wrong cs at 0x000AE000, retry... read error recovered warning: wrong cs at 0x00D3A800, retry... warning: wrong cs at 0x00D3A800, retry... warning: wrong cs at 0x00D3A800, retry... warning: wrong cs at 0x00D3A800, retry... warning: wrong cs at 0x00D3A800, retry... warning: wrong cs at 0x00D3A800, retry... warning: wrong cs at 0x00D3A800, retry... warning: wrong cs at 0x00D3A800, retry... warning: wrong cs at 0x00D3A800, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? error: wrong answer: 71 Probably errors exist during flash read operation. Do you want to repeat read operation ? warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? error: wrong answer: CD Probably errors exist during flash read operation. Do you want to repeat read operation ? warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... error: too many retries during read operation Finished, time used: 1487 sec Remove/Install battery now ! thanking you PATEL TELECOM |
06-01-2009, 22:19 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It may be problem with your cable or box. If software can detect phone and can read version this means that software works, if you see errors during reading it may be cable/box problem. Try to use another cable. |
06-02-2009, 11:05 | #3 (permalink) |
Member: 397884 Status: Offline Sonork: 100.1587035 Thanks Meter: 168 | but sir in motorola phone i try three cable but no detect and problem of box so plese how i repair box plese thanks in advance Thanking you, Patel telecom |
VERY VERY STRANGE PROBLEM WITH W810i | .::MoBiLeDoC::. | Sony Ericsson Hardware Repair | 14 | 04-16-2011 17:27 |
very very strange problem with nokia 1101 its urgent | sallu | Nokia Hardware & Hardware Repair | 3 | 12-26-2006 16:14 |
UFS3 + HWK very very strange problem ???????????? | makroud | UFS2 + UFS3-Tornadoflasher | 2 | 04-13-2006 10:14 |
s300m very very very strange problem | mp3hot | Trident/AGERE Platform | 0 | 02-03-2004 20:29 |
Very Very Strange Problem On Be4 | Pandemonio100 | Alcatel & TCL Old Models | 1 | 06-25-2002 20:00 |
