VFD 610 Frp hello , problem remove frp with cm2 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:30 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x07000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with SLA Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : DONE Boot Error! Operation Failed Elapsed: 00:00:08 |
VFD 610 frp You want special custom solution? Android mtk is not ok for you? |
what..................... !!!!!!!!! |
this is secure boot maybe cant done by cm2 , but u can bypass by Quick Shorcut maker.apk |
Quick Shorcut maker.apk not Work:( |
10000000% work i did 10+ phones if u have phone on your hand contracet to me skype [email protected] |
Please help me remove account google for VDF610 Thank you in advance for your efforts |
please contract me on skype i'll help u to remove it , its very easy |
Download Quick Shorcut maker.apk 1- Scarch Setup Wizard 2-touch on Setup Wizard google service/try/next /next/ then phone ask u to slide menu on the top/ go to setting /enable adb /make hard reset if not work try same way Setup Wizard google service 3rd option Tool Easy 1000000% done |
cm2 has become dead.....miracle is best. |
I only found that Setup Wizard, not Setup Wizard google service can explain more to me |
https://s18.postimg.org/sh03iw5jd/26...67526554_n.png after touch Setup Wizard then use 1st number then ask to next and flow then.................. |
after touch on Setup Wizard, go all Setting back |
then try next and ask to slide menu on the top if problem post screenshot if u cant be done wait some days once i get phone i make video and post u |
