01-13-2020, 17:45 | #1 (permalink) |
No Life Poster Join Date: Oct 2012 Location: Pakistan ,Sahiwal ,Bwn Age: 30
Member: 1819120 Status: Offline Sonork: 100.1648344 Thanks Meter: 1,448 | Vgotel I12 MTK 6261 Read Flash File Done By CM2 Vgotel I12 MTK 6261 Read Flash File Done By CM2 Code: Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 35 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : C862AB456FDA9F04F5F807617313E031 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00ED , [GigaDevice] GD25LQ64 [0] : FLASH_DIE : 00C8 0060 0017 0000 [0] : FLASH_LEN : 0x00800000 SDS_INFO : 0x007FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Reading Flash Content now ... Read Flash now Read Ok , 8388608 bytes read Check and collect compile info File_Info : FISE61A_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_MP_V2_F8.bin FileVersion : MAUI.11C.W13.52.MP.V2.F8 Saved to : C:\InfinityBox\CM2MTK\Read_out\FISE61A_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_MP_V2_F8.bin Done! Elapsed: 00:00:31 Reconnect Power/Cable! Br Muzammal Mudassar |
01-13-2020, 18:03 | #2 (permalink) |
Member: 1819120 Status: Offline Sonork: 100.1648344 Thanks Meter: 1,448 | [QUOTE=muzammal mudass;13968314] Vgotel I12 MTK 6261 Read Flash File Done By CM2 Code: Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 35 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : C862AB456FDA9F04F5F807617313E031 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00ED , [GigaDevice] GD25LQ64 [0] : FLASH_DIE : 00C8 0060 0017 0000 [0] : FLASH_LEN : 0x00800000 SDS_INFO : 0x007FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Reading Flash Content now ... Read Flash now Read Ok , 8388608 bytes read Check and collect compile info File_Info : FISE61A_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_MP_V2_F8.bin FileVersion : MAUI.11C.W13.52.MP.V2.F8 Saved to : C:\InfinityBox\CM2MTK\Read_out\FISE61A_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_MP_V2_F8.bin Done! Elapsed: 00:00:31 Reconnect Power/Cable! Br Muzammal Mudassar |
