03-16-2009, 07:38 | #1 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 200548 Status: Offline Thanks Meter: 104 | beetel EC005 unlocked sucessfull module v2.58 Device: Beetel-EC005 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: C625_BEETEL_PCB01_GSM_MT6205B_DN.KAA625A_INE_EN_HI _1_11_630.BIN ver. sw 2: KAA625A_INE_EN_HI_1.11.630, 00000000 ffs offset/size: 00300000/00100000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[C625_BEETEL_PCB01_GSM_MT6205B_DN.KAA625A_INE_EN_HI _1_11_630.BIN]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[C625_BEETEL_PCB01_GSM_MT6205B_DN.KAA625A_INE_EN_HI _1_11_630.BIN]_20090316-120749.B0E.bin flash: 01227E221A2201:18E59F00000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done Special operation ... detecting additional parameters... ..... flash: 01227E221A2201:18E59F00000000 flash: 01227E221A2201:18E59F00000000 Write: area 0/1 ........... additional parameters detected Ok Special operation Done Write ... flash: 01227E221A2201:18E59F00000000 Write: eeprom Write Done Finalization ... Finalization Done Finished, time used: 182 sec Remove/Install battery now ! thanx infinity team |
The Following User Says Thank You to bittubansal For This Useful Post: |
03-16-2009, 21:59 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
BEETEL EC005 by BSNL | EMOTION BBSR | Infinity-Box | 23 | 11-02-2014 18:46 |
Beetel ec005 | EMOTION BBSR | ET-BoX | 6 | 11-21-2008 17:35 |
beetel ec005 | honolulu | Infinity-Box | 1 | 08-09-2008 23:52 |
