11-07-2015, 11:16 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: india Age: 40
Member: 101117 Status: Offline Thanks Meter: 466 | virus still exist even after cleaning with smart AV i cleaned it by smart av in cm2 this is log Operation : Remove Viruses [SmartAV] [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004D3447315943024600EE1950B5 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : CY1G4 [eMMC] : FLASH_CID : 1501004D3447315943024600EE1950B5 [eMMC] : FLASH_EXT : 00200000/00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 18 Removing infected files and scripts ... SmartAV Report : Removed 18 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:02:40 Reconnect Power/Cable! formated also logs Operation : Format FileSystem [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004D3447315943024600EE1950B5 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : CY1G4 [eMMC] : FLASH_CID : 1501004D3447315943024600EE1950B5 [eMMC] : FLASH_EXT : 00200000/00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! but still there hola launcher n gives lots of error. plz guide me wat i do? |
11-07-2015, 18:14 | #3 (permalink) |
Member: 101117 Status: Offline Thanks Meter: 466 | I TRIED IN 1.35 AND ALSO ON 1.34 HERE R LOGS OF 1.34 Operation : Remove Viruses [SmartAV] [ v1.34 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004D3447315943024600EE1950B5 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : CY1G4 [eMMC] : FLASH_CID : 1501004D3447315943024600EE1950B5 [eMMC] : FLASH_EXT : 00200000/00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 5 Removing infected files and scripts ... SmartAV Report : Removed 5 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:00:56 Reconnect Power/Cable! STILL SAME ISSUE PLZ GUIDE ME |
11-08-2015, 06:44 | #5 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Sometime just original FW flashing will do the job, or in case of missing orig FW - cleaning one by one threads instances by hand ... |
