vivo 1716 MSM8953 im3i invalid problem device: Code:
Created by Infinity-Box (c) Chinese Miracle II (c) 2017
Device Brand : vivo
Device Manufact.: vivo
Device Model : msm8953_64
Device CPU : MSM8953
Device IntName : PD1708F_EX
Device Version : 7.1.2
CU_SWVer : vivo
Device Compile : 31/08/2017 17.38.21
Device ExtInfo : vivo 1716 backup and wipe security Code:
Operation : EDL Security Operation [ v1.16 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 625 [MSM8953]
ID_BLOCK_S : 003606A4
ID_BLOCK_L : 8D4873921D80510D896309ED093488DB
ID_BLOCK_L : EF542EDDD3DF16AF16AFA1E24D477AC0
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2
Boot Ok!
Backup Security Partitions
Backup : FSG
Backup : MODEMST1
Backup : MODEMST2
Backup saved to : D:\INFINITY\CM2QLM\Backup\MSM8953_[0009A0E1]_003606A4_SEC\
Done!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Wipe Security Partitions
Erase : FSG
Erase : MODEMST1
Erase : MODEMST2
Done! Repair im3i failed (security already wiped) Code:
Operation : Write Security [ v1.16 ]
1. Enable DiagInterface on device [ by Code, Root or other way ]
2. Make sure DiagDrivers installed and work correct
Wait for phone...
Device Found!
Initialize ...
DiagMode initialized!
MSMHW : 000009A0
MODHW : 0000100E
BUILD : MPSS.TA.2.3.c1-00430-8953_GEN_PACK-1.108903.1.109730.1
RTIME : Sep 1 201701:01:21
BTIME : Jul 28 201702:00:00
DEVST : 8953.gen
Update IMEI[1] : 865246546xxxxxx
Record update FAILED! READ-ONLY! Security Wipe required!
Update IMEI[2] : 865246546xxxxxx
Write done! Reboot device, if it not restart!
Hint : QCN write and Factory Reset is required to finish process completely!
Done!
Elapsed: 00.00.03
Reconnect Power/Cable!
what is the problem?
wbr |
