kamal_singla | 04-08-2021 08:31 | Quote:
Originally Posted by naveedullah0044
(Post 14370126)
https://i.ibb.co/0nBHyLG/vivo-2.png Code:
Operation : HW Report [ v2.21 ]
HWreport : Mode : eMMC
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM18)
MODE : BOOTROM
PORT : 18
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200
CODE : Merlot
TYPE : MODERN RAPHAEL
BROM : MEID : 7705E37D49404F8068C7614715A69C29
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+EXT
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
MODE : 0_base : BASE_v2044 | Manual : Disabled
BROM : SOCID : 3B65AC82AF1B0724647D6DC118C2B8467B6AC04B893B96DC9A8F3A40069FE685
BROM : SLA : Local Auth
BROM : SLA : Auth Started!
BROM : SLA : Auth Passed!
BROM : SLA : 0x0000001F
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6761
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : INFINITY
EMI : SRC : PRELOADER_INFINITY_0
EMI : CNT : 0001
EMI : Init EMI from INTERNAL DB
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x0003A000 [ 232.00 KB ]
DRAM: 0x80000000 [ 2.00 GB ]
EMMC: 150100514536334D4203AE3A9A0FB53F
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x3A3E00000 [ 14.56 GB ]
CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 68692E0644CDECB359B970DE4D10C035
DA : USB : HIGH-SPEED
Boot done!
Memory Info :
CID : 150100514536334D4203AE3A9A0FB53F
CSD : D02701320F5903FFF6DBFFEF8E40400D
MEM : VEN : SAMSUNG | OEM : 01 | DEV : QE63MB
DAT : Size: 14910 MB, Max.Speed: 52000 kHz, blklen(512), nblks(30535680), ro(0)
EXT_CSD Info :
EXT_CSD rev. : v1.8 ( MMC v5.1 )
CSD struct rev. : v1.2
Supported command sets : 1h
HPI features : 1h
BG operations support : 1h
BG operations status : 0h
Correct prg. sectors : 0h
1st init time after part. : 3000 ms
Min. write perf.(DDR,52MH,8b): 0h
Min. read perf. (DDR,52MH,8b): 0h
TRIM timeout: 0 ms
Secure feature support: 55h
Secure erase timeout : 8100 ms
Secure trim timeout : 5100 ms
Access size : 3584 bytes
HC erase unit size : 512 kbytes
HC erase timeout : 300 ms
HC write prot grp size: 8192 kbytes
HC erase grp def. : 0h
Reliable write sect count: 1h
Sleep current (VCC) : 7h
Sleep current (VCCQ): 7h
Sleep/awake timeout : 26214400 ns
Sector count : 1d1f000h
Min. WR Perf. (52MH,8b): 0h
Min. Read Perf.(52MH,8b): 0h
Min. WR Perf. (26MH,8b,52MH,4b): 0h
Min. Read Perf.(26MH,8b,52MH,4b): 0h
Min. WR Perf. (26MH,4b): 0h
Min. Read Perf.(26MH,4b): 0h
Power class: 0
Power class(DDR,52MH,3.6V): 0h
Power class(DDR,52MH,1.9V): 0h
Power class(26MH,3.6V) : 0h
Power class(52MH,3.6V) : 0h
Power class(26MH,1.9V) : 0h
Power class(52MH,1.9V) : 0h
Part. switch timing : 2h
Out-of-INTR busy timing: ah
Card type : 57h
Command set : 0h
Command set rev.: 0h
HS timing : 0h
Bus width : 0h
Erase memory content : 0h
Partition config : 48h
Boot partition size : 4096 kbytes
Boot information : 7h
Boot config protection: 0h
Boot bus width : 2h
Boot area write prot : 0h
User area write prot : 0h
FW configuration : 0h
RPMB size : 4096 kbytes
Write rel. setting : 1fh
Write rel. parameter: 14h
Start background ops : 0h
Enable background ops: 2h
H/W reset function : 1h
HPI management : 0h
Max. enhanced area size : 3a3h (7626752 kbytes)
Part. support : 7h
Part. attribute: 0h
Part. setting : 0h
General purpose 1 size : 0h (0 kbytes)
General purpose 2 size : 0h (0 kbytes)
General purpose 3 size : 0h (0 kbytes)
General purpose 4 size : 0h (0 kbytes)
Enh. user area size : 0h (0 kbytes)
Enh. user area start: 0h
Bad block mgmt mode: 0h
Overall status :
PERM_WRITE_PROTECT : Disabled
TEMP_WRITE_PROTECT : Disabled
MLC status : 50% - 60% used
SLC status : 50% - 60% used
EOL status : Normal ( Less than 80% reserved blocks used )
RPMB : RPMB KEY EXISTS! [State : NOT CLEAN : UNUSABLE]
Done!
Elapsed: 00:00:22
Operation : Identify [ v2.21 ]
Mode : FLASH
MODE : BOOTROM
PORT : 18
BROM : Init BROM
BROM init passed!
CODE : Merlot
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0001
EMMC:
Boot done!
Patch Level : O11019
Display ID : O11019 release-keys
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2021-01-01
Build Time : 15.01.2021
Product Model : vivo 1812
Product Brand : vivo
Product Name : PD1732CF_EX
Product Device : PD1732CF_EX
Product Manfct : vivo
Product Info : k61v1_64_bsp
Board Platform : mt6761
USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption *)
NVRAM check : Passed!
NVRAM : SEC NORMAL [ No extra security ]
Backup sensetive data [ 15 ]
Backup path : Backup\MT6761__68692E0644CDECB359B970DE4D10C035\
Backup done!
STORAGE : LifeStatus : eMMC : OK!
Done!
Elapsed: 00:00:25
Operation : Read Firmware [ v2.21 ]
ExtSparse : Enabled
ForceRead : Enabled
MODE : BOOTROM
PORT : 18
BROM : Init BROM
BROM init passed!
CODE : Merlot
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0001
EMMC:
Boot done!
Ver. CodeName : REL
MT6761__vivo__vivo_1812__8.1.0__O11019__k61v1_64_bsp
Read : preloader.bin
Read : recovery.img
Read : backup.img
Read : survival.img
Read : cust.img
ExtSparse : Compression ratio : 95%
Read : persist.img
ExtSparse : Compression ratio : 58%
Read : efuse.img
Read : md1rom.img
Read : spmfw.img
Read : tinysys-scp.bin
Read : tinysys-sspm.bin
Read : nvram.bin
Read : lk.bin
Read : boot.img
Read : logo.bin
Read : odmdtbo.img
Read : tz.img
Read : vendor.img
ExtSparse : Compression ratio : 33%
Read : system.img
ExtSparse : Compression ratio : 9%
Error : Failed to convert data! AV or UAC issue???
>>> Check your system, antivirus exclude list, UACsettings and free disk space!
Reconnect Power/Cable!
:rolleyes::rolleyes: | Quote:
(Post 14370140)
| Check your system, antivirus exclude list, UACsettings and free disk space! |
