07-12-2022, 14:24 | #1 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Torun, Poland Age: 40
Member: 25996 Status: Offline Thanks Meter: 253 | Vivo V2109 - testpoint, semi-fail Code: Product Brand : vivo Product Device : 2109 Product Model : V2109 Product Name : 2109_EEA Patch Level : SP1A.210812.003 Display ID : SP1A.210812.003 release-keys Ver. CodeName : REL Ver. Release : 12 Sec. Patch : 2022-05-01 Build Time : 10.05.2022 Product Info : k69v1_64 Product Manfct : vivo Product Board : k69v1_64 Board Platform : mt6768 Code: Operation : Identify [ v2.34 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM224) MODE : BOOTROM PORT : 224 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : D008BF2C9EEF79E0F125EFE05DD6770C BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 4E3A1450EAA6E9F41169970C66CF50EF05E9B408A241EF66C016A876CAB62931 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : All_Vivo_MT6769_MT6768_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 1501005756364A4D42045C33DCC68893 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 5756364A4D42 : PRV : 0x04 EMMC: VEN : SAMSUNG : WV6JMB EMMC: SNN : 1546902726 ( 0x5C33DCC6 ) , MF : 8/2021 EMI : DEV : FireFly EMI : SRC : preloader_k69v1_64.bin EMI : CNT : 0010 EMI : Init EMI from INTERNAL DB DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Error : Fail to init protocol! >>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! Code: Operation : Identify [ v2.34 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM224) MODE : BOOTROM PORT : 224 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : D008BF2C9EEF79E0F125EFE05DD6770C BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 4E3A1450EAA6E9F41169970C66CF50EF05E9B408A241EF66C016A876CAB62931 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : CHANGE : v2112 AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 1501005756364A4D42045C33DCC68893 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 5756364A4D42 : PRV : 0x04 EMMC: VEN : SAMSUNG : WV6JMB EMMC: SNN : 1546902726 ( 0x5C33DCC6 ) , MF : 8/2021 DA : EMI : Failed to get EMI info from selected source! DA : EMI : EMI NUM is non-zero! Revert it back to 0 EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0004 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERR : 0xC0070004 ERR : DA_HASH MISMATCH Boot done! It can be read when i switch platform to "infinity firefly smartphone": Code: Operation : Memory Tool Init [ v2.34 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM24) MODE : BOOTROM PORT : 24 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : D008BF2C9EEF79E0F125EFE05DD6770C BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 4E3A1450EAA6E9F41169970C66CF50EF05E9B408A241EF66C016A876CAB62931 BROM : Sending FireFly FireFly : Starting ... FireFly : Init Core FireFly : Core init done! FireFly : Running : v05.05.05 on MT6768 FireFly : eMMC init passed! EMMC: CSD : D02701320F5903FFF6DBFFEF8E40400D EMMC: CSD : TEMP_WRITE_PROTECT: False EMMC: CSD : PERM_WRITE_PROTECT: False EMMC: CID : 1501005756364A4D42045C33DCC68893 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 5756364A4D42 : PRV : 0x04 EMMC: VEN : SAMSUNG : WV6JMB EMMC: SNN : 1546902726 ( 0x5C33DCC6 ) , MF : 8/2021 EMMC: EXTCSD : rev1.8 ( eMMC 5.1 ) EMMC: EXTCSD [CONFIG] : 0x48, 0x02, 0x01 EMMC: EXTCSD [PARTITION_CONFIG] : 0x48 EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x02 EMMC: EXTCSD [RST_N_FUNCTION] : 0x01 EMMC: EXTCSD [PART_S_COMPLETED] : False EMMC: EXTCSD [SIZE] : Market : 128 GB EMMC: EXTCSD [SIZE] : Actual : 0x1D1EC00000 [ 116,48 GB ] EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used ) EMMC: EXTCSD [EOL_A] : SLC status : 0% - 10% used EMMC: EXTCSD [EOL_B] : MLC status : 0% - 10% used EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] USER : 0x1D1EC00000 [ 116,48 GB ] DA : USB : HIGH-SPEED Boot done! Set default path : C:\InfinityBox\CM2MT2\phdata\ Ready! Close MemoryTool session |
07-14-2022, 01:42 | #6 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,053 | Quote:
Br, xerraco | |
07-15-2022, 11:26 | #7 (permalink) |
Member: 25996 Status: Offline Thanks Meter: 253 | OK, so it was a hardware issue after all. One of the capacitors under the eMCP was slightly cracked, most likely during cutting EMI shield. It was causing a short, possibly interfering with RAM communication. After solving this, the phone can be read correct via bootrom mode using testpoint. |
The Following 4 Users Say Thank You to KrzychuG For This Useful Post: |
09-30-2023, 10:53 | #8 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | Vivo Y33s V2109 frp without test point done(Android 13,Security01.09.2023) Vivo Y33s V2109 frp without test point done(Android 13,Security01.09.2023) <code>S/N: 07EXXXXX v0156 Chinese Miracle II - MT2 Service Tool v2.50a2 (beta) Init log engine... Ok Build directories tree... Ok Backup files: C:\InfinityBox\CM2MT2\backup\ Compact backup files... Backup files: 79 dirs: 1 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 110 profiles... Ok libusb: v1.2.6.0 Init environment... Ok Load IDBase v418494 Ok Check for updates [boot-pack]... You have latest version [2.43] installed Check for updates [CM2MT2]... You have latest version [2.50] installed Telegram Channel: @InfinityBox Telegram Chat: @InfinityBoxTalks Account: https://infinity-box.com/service/ Update configuration... Configuration [12192] updated Load IDBase v418494 Ok --------------------------------------------------------- DA selected: Vivo | SEC_2023 | MTK_AllInOne_DA_v3.fdaaf7f6.bin Operation: Identify Device [ v2.50a2 (beta) ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Mode: FLASH Port: Both [ B + P ] [+] Read deep info: PRL, HW, DEBUG [+] Auto-EMI [+] FireFly-Over-DA extended protocol [+] Vendor-Specific Analyzer [-] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM91) MODE [0]: PRELOADER PORT; PORT: 91 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 19E10856AE98949D40C0AF66B27E8A0662508A25C0B4E70E5B F6D969EFE9FA30 AGENT: MANUAL: Vivo: SEC_2023 [ecb438fd] C:\InfinityBox\CM2MT2\boot\Vivo\SEC_2023\MTK_AllIn One_DA_v3.fdaaf7f6.bin Looking for suitable BootChain in DA... Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 1501005756364A4D4204F2EDCE078843 crc Ok Ven: Samsung OEM: 256 ID: 5756364A4D42 [WV6JMB] PRV: 0x04 SNN: 4075671047 [0xF2EDCE07] MM/YY: 8/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1EC00000 [ 116.48 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: B8201A53FA7ED4A175FD158CD5FE7587 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 50 Select info source... Ok Product Brand: vivo Product Device: 2109 Product Model: V2109 Product Name: 2109_EEA SW: vivo/2109_EEA/2109:12/SP1A.210812.003/compiler08301625:user/release-keys Patch Level: SP1A.210812.003 Display ID: SP1A.210812.003 release-keys SW Version: compiler08301625 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-09-01 Build Time: 30.8.2023. 08:45:26 Product Info: k69v1_64 SW: full_k69v1_64-user 12 SP1A.210812.003 compiler08301625 release-keys Product Manfct: vivo Product Board: k69v1_64 Board Platform: mt6768 Strategy: [vivo] Firmware ID: MT6768_vivo_V2109_OSv12_SP1A.210812.003_k69v1_64 Verify firmware [MT6768_vivo_V2109_OSv12_SP1A.210812.003_k69v1_64]... Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... BBK_R0MP1_K69T_V1_64_BSP_MDBIN_PCB01_MT6768_S00.MO LY_LR12A_R3_TC19_PR2_SP_V1_P18 Analyze nvram... NVRAM: Items: 0xB6 Size: 0x13ED3F State: Ok WiFi MAC: AA0036004400 BlTh MAC: D463DE335410 IMEI[1]: 861616058053225 IMEI[2]: 861616058053233 Verify device config... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6768__F872C8775724C 9E751A5BDE178F320EC\ Items to check: 20 Read [29] NVRAM Read [13] NVDATA Read [26] PROINFO Read [40] LK Read [12] NVCFG Read [22] PROTECT1 Read [1] PGPT Read [21] PERSIST Read [0] PRELOADER Done 9 files Compress: C:\InfinityBox\CM2MT2\backup\MT6768__F872C8775724C 9E751A5BDE178F320EC\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6768__F872C8775724C 9E751A5BDE178F320EC.7z Finished STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Analyze preloader... EMI: MT6752 preloader_k69v1_64.bin with 16 memory type(s) 1. eMMC LP_DDR4X ID: 150100335636434D42 Samsung 3V6CMB RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 90014A684445615033 Hynix hDEaP3 RAM: 6.00 Gb 3. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 13014E47314A395139 Micron G1J9Q9 RAM: 6.00 Gb 6. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 10. eMMC LP_DDR4X ID: 13014E47314331324C Micron G1C12L RAM: 8.00 Gb 11. eMMC LP_DDR4X ID: 150100335636434142 Samsung 3V6CAB RAM: 6.00 Gb 12. eMMC LP_DDR4X ID: 1501005756364A4D42 Samsung WV6JMB RAM: 8.00 Gb 13. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 14. eMMC LP_DDR4X ID: 150100445036444242 Samsung DP6DBB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445636444242 Samsung DV6DBB RAM: 4.00 Gb 16. eMMC LP_DDR4X ID: 13014E473243323139 Micron G2C219 RAM: 4.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 69v1_64.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 69v1_64.bin [4f19b68c]... Stored Get MDM state... Analyze FS layout... Found 6 item(s) Request... Ok remote config loaded: 6 item(s) Something is in progress, do not touch me! -------------------------------------------------------- ------------------------------------------------------- S/N: 07EXXXXX v0156 Chinese Miracle II - MT2 Service Tool v2.50a2 (beta) Init log engine... Ok Build directories tree... Ok Backup files: C:\InfinityBox\CM2MT2\backup\ Compact backup files... Backup files: 80 dirs: 1 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 110 profiles... Ok libusb: v1.2.6.0 Init environment... Ok Load IDBase v418494 Ok DA selected: Vivo | 1802-pd1803 | MTK_AllInOne_DA.2018-04-19.66e419cc.bin DA selected: Vivo | SEC_2023 | MTK_AllInOne_DA_v3.fdaaf7f6.bin Operation: Reset Settings/Format FS [ v2.50a2 (beta) ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM91) MODE [0]: PRELOADER PORT; PORT: 91 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 19E10856AE98949D40C0AF66B27E8A0662508A25C0B4E70E5B F6D969EFE9FA30 AGENT: MANUAL: Vivo: SEC_2023 [ecb438fd] C:\InfinityBox\CM2MT2\boot\Vivo\SEC_2023\MTK_AllIn One_DA_v3.fdaaf7f6.bin Looking for suitable BootChain in DA... Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 1501005756364A4D4204F2EDCE078843 crc Ok Ven: Samsung OEM: 256 ID: 5756364A4D42 [WV6JMB] PRV: 0x04 SNN: 4075671047 [0xF2EDCE07] MM/YY: 8/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1EC00000 [ 116.48 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: B8201A53FA7ED4A175FD158CD5FE7587 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 50 Select info source... Ok Product Brand: vivo Product Device: 2109 Product Model: V2109 Product Name: 2109_EEA SW: vivo/2109_EEA/2109:12/SP1A.210812.003/compiler08301625:user/release-keys Patch Level: SP1A.210812.003 Display ID: SP1A.210812.003 release-keys SW Version: compiler08301625 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-09-01 Build Time: 30.8.2023. 08:45:26 Product Info: k69v1_64 SW: full_k69v1_64-user 12 SP1A.210812.003 compiler08301625 release-keys Product Manfct: vivo Product Board: k69v1_64 Board Platform: mt6768 Strategy: [vivo] SmartInfo: Android Ver: 12 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Verify device config... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6768__F872C8775724C 9E751A5BDE178F320EC Stage: ANDROID OS [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Process USERDATA... Ok Stage: FRP FRP Off Stage: SMART Stage: Vendor Extra Ok Done: 00:00:37 Reconnect Power/Cable now </> |
